...and then when I respond that I've been teaching in the field of computer graphics, all of a sudden "experience doesn't matter".
That is truly classic deflection... and - in terms of my responding to you - the proverbial straw.
Anyway, as amusing as this has occasionally been, your posts have been - and continue to be - a massive waste of my time. So, after 3 and a half years on this forum, I've finally run into someone worthy of my"Ignore List".
i ment that as soon as somebody disagrees, folks like you will start with displaying the diplomas instead of knowledge.
i see what you say and i say some of those things are rubbish.
while others are quite good.
if you were teaching something, it doesn't mean you know all about it.
you got that answer after you asked:
(BTW, what exactly is YOUR experience with image processing again?)
i didn't ask about your experience, i just said you don't seem to understand stuff i say because you're not that much into some subjects. regardless of your diploma.
i don't care about your school(s) i just say some of the things you said were not right.
oh yeah, i never ignore.
pa3bca:
The waveform of the 1074Z is indeed a bit more coarse/"blocky". I assume that is because the 1074Z has a lower waveform update rate in combination with a different implementation of intensity grading (Marmad would know).
no, it's just that you can scale those finite number of adc levels
to finite (but different) number of display pixels
in different ways.you will see simillar effects if you would resize some image with different resizers.
(1k being an example of a crappy resizer)
that's much more dissapointing about 1k series than the difference in fonts and displays.
(i feel scope is not a device to read books on anyway)
but waveforms are not that jaggy in reality, they are much more like waveform on rigol 2k displays.
(in the end it means 1k is having less vertical resolution)
these differences i would attribute to different hardware mfrs and their preferences for particular (newer) technoligies etc.
i never liked cleartype and alike, so i would prefer "older" style of 2k when it comes to fonts.
but again, it's doesn't matter much.
i would prefer to see a better vertical resolution than a bigger fonts.
