I played with my oscilloscope some more and got a couple more results I think are interesting.
I fed it train of 5-V, 70-ns-wide pulses spaced at 1-ms intervals and set the time base and memory depth appropriately to test peak detect mode. I changed from dots to vectors for this so the pulses are lines instead of hard-to-see dots.
First in normal mode:
As expected the pulses were captured erratically and unreliably in normal mode. Each sweep showed a different number of pulses in different spots.
Then in peak detect mode:
Peak detect mode worked beautifully and did exactly what it's supposed to do. So now I know turning on peak detect mode does something, and the unit isn't simply stuck in peak detect mode.
I'm wondering now if that second stage of peak detect mode I speculated about in my last post might be stuck on, meaning that turning peak detect mode on and off is only controlling that first stage of downsampling. I know that scenario might sound a little farfetched, especially since I'm guessing about how peak detect mode works exactly. However, I think that scenario would be consistent with what I'm seeing. The double line with nothing in the middle and the points all displayed at the extremes of the noise amplitude looks so consistent with what I would expect out of peak detect mode that I'm still not satisfied a peak detect bug isn't somehow behind this.
I also fed a 4-Vpp, 1-MHz sine wave into the oscilloscope while in normal mode. With the time base set very slow compared to the signal's period, this is what I got with dots:
It looks like the envelope of the signal, which is what I would expect to see under these conditions with peak detect mode enabled. Nothing changed on the screen when I varied the frequency around 1-MHz, so I don't think this effect is caused by aliasing. As in the other examples of double lines, it looks like the fog you'd expect to see if displaying vectors because of the lines connecting the two lines of points.
Could this be a more extreme example of this double line issue?
