If you do take lxi-tools for a test spin please install the latest versions of liblxi and lxi-tools from https://lxi.github.io
I just did, then sniffed the actual LAN data packets using Wireshark.
First, lxi-tools is a very nice and useful tool, thank you for making it available.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Second, I found it very hard to install, even if I'm familiar with Linux. By familiar I mean able to follow README instructions, and able to use the command line, but not being a Linux developer. The problem was that there were no binary, so I need to compile from sources. In the README file it says "./configure", "make", "make install", which won't work, because there is no "./configure". By looking inside various files I realized that I should generate the ./config file myself, then after a lot of googling I found out about autoreconf and so on.
![Flogging A Dead Horse :horse:](https://www.eevblog.com/forum/Smileys/default/DeadHorse.gif)
This is probably trivial for any Linux developer, but it was not for me. IMHO the build and installation instruction should have been something like these:
cd ~
mkdir lxi-tools
cd lxi-tools/
git clone https://github.com/lxi/liblxi
cd liblxi/
su
apt-get update
apt-get install automake
apt-get install autogen autoconf libtool
./autogen.sh
./configure
make
make install
cd ..
git clone https://github.com/lxi/lxi-tools
cd lxi-tools/
./autogen.sh
apt-get install libreadline-dev
./configure
make
make install
export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/usr/local/lib"
lxi
For my Debian 8, some of the build tools were not installed by default.
Third, the lxi-tool is using a different protocol, VXI-11, and different ports. lxi-tools is not using TCP/5555, I guess that is why the hang is not reproducible when using VXI-11.
TBH, the DS1000Z specifications are "Conform to LXI CORE 2011 DEVICE class instrument standards", and I couldn't find any mention in the Rigol DS1000Z manuals about using TCP and port 5555, like in a remote SCPI sent by Telnet or Netcat/TCP.
Unless LXI CORE 2011 requires SCPI to work over a raw TCP socket (it might require, but at a draft look I couldn't find any required feature about plain SCPI text sent over LAN), I guess SCPI text sent over a raw TCP socket is just an undocumented feature, so even if the TCP hangs when using netcat, then we can not file a bug about it.
