havent read all pages, maybe this is a repeat anyway... nothing special just some UI brought from less buggy and enjoyfull DS1052E series, i dont ask for new features, just expecting the same or better performance as what i used to (older DS1052E), namely:
1) encoders for intensity, channel position, horizontal time position, and trigger level (the four smaller knobs at the top of two bigger knobs)... the new DS1054Z knobs respond are very slow, with exception to intensity knob when used to select sub menu which is overly sensitive (super fast). the older DS1052E smaller knobs respond and speed all are about perfect, not too fast not too slow. i dont know why the later programmer want to reinvent the new speed rate from better to worse.
2) clipped signals should not be visible, just as older DS1052E, instead of confusing ceiling or bottomed horizontal (clipped) line. again, why reinvent from better to worse?
3) when we set horizontal time far from center, or trigger level far up or down... and then we set time div or V/div to smaller value, making time offset or trigger level goes out of bound, and then the scope will reset the time offset and trigger level to smaller magnitude, when we restore our previous time/div and V/div, time offset and trigger level is not what it was... older DS1052E does not exhibit this symptom, it remembers the larger offset and trigger level set by user earlier. this new DS1054Z cannot remember it (reset to nearly zero), maybe too much memory all 24Meg are used up for data capture, no space for user settings
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
still new with this ver 4.03 DS1054Z (modded to DS1104Z already), will search for another bugs, hopefully not much...
