Hi all!
Sorry to be a pain, but I've tried installing the Rigol firmware from konnor to enable plugins on my MSO1074Z, but after copying the firmware, the scope starts analyzing it and then reports that the firmware update failed. I've tried several times, re-extracting the .GEL file and re-copying it to the USB stick, but they all fail. I also tried downloading the file where pluses was corrected to pulses from Adrian_Arg.'s post, but it also fails to update.
I am running the current RIGOL firmware, 00.04.04. SP4.
Does anyone have any suggestions as to what else I could try to get the plugin firmware update to work? Any help would be most appreciated!
