Author Topic: RIGOL DS 1054Z or TEKTRONIX 2440  (Read 12464 times)
Offline GasGasTopic starter
  • Country: br
« on: January 10, 2017, 11:39:01 pm »
I would like to read some opinions on which oscilloscope to buy between these two options. I currently own a Tektronix 2465B and a 2467B. There was a sales opportunity for the 2465B and I wanted to buy my first digital oscilloscope. I work with maintenance of audio and video equipment and until today I did not feel the need to use a DSO. I really take into consideration the quality of the Tektronix brand, but I am afraid the 2440 is already far behind in relation to Chinese Rigol. A year ago, I paid for the 2467B almost twice the price of the Rigol DS1054 and I do not regret it, because it was in excellent condition with less than 1000 hours of use, and analyzing a video signal on it is incredible. The 2440 that I am considering buying is a little more expensive than the new Rigol DS1054.
Anxious for your opinions.
Sorry for the bad English, I'm using Google Translate.
Online ebastler
Re: RIGOL DS 1054Z or TEKTRONIX 2440
« Reply #1 on: January 11, 2017, 05:35:17 am »
A couple of points in favor of a modern DSO (Rigol or any other) over the 2240:
  • The color screen and automated measurement of curve parameters are convenient. (Even if we know that the DS1054Z only uses its screen data buffer to derive the measurements, that's more convenient and more precise than eyeballing yourself...)
  • Much more compact than the old cathode-ray tube scopes. Depending on your bench setup, this may not matter at all, or may be a killer argument.
  • Faster signal processing. The 2240 seems to have a particular weakness in its waveform update rate -- only 26 waveforms per second. That's pretty useless for finding sporadic glitches, for example.
I do not have hands-on experience with the 2240; maybe someone else can add more model-specific comments. I would suggest hanging on to the 2467B, and complementing it with a modern DSO. The Rigol DS1054Z is still a good choice, if that's where your price range is.
EDIT: I might add that the physical build quality of the DS1054Z is actually quite good -- better than the slightly toy-style front panel design might suggest... The enclosure and internal shielding are surprisingly sturdy, the screen is protected by a solid glass pane with anti-reflection surface, and the encoder knobs feel solid enough to me. From a human factors perspective, the non-detented encoder for menu selections and the fan noise are mentioned most often as nuisances. Personally, I did exchange the encoder with a detented type eventually, but I don't mind the fan noise at all. I use the scope in a quiet room, and the fan is definitely very audible, but the sound is not annoying for my ears.
« Last Edit: January 11, 2017, 06:31:25 am by ebastler »
Offline JPortici
« Reply #2 on: January 11, 2017, 06:57:24 am »
[edited out to try at prevent just another flame war]
recap: i don't like to use cheap DSOs. I use other tools in conjunction with a PC.
I always felt i wasted my money on the 1054z.
I too have a tek + 1054z combination at home and the only thing i trusted it to do was single shot capture. I used better tools to do protocol decoding when needed.
I don't find much advandage in a DSO for audio work as it can be terrible for accurate vertical axis measurements, fft and such due to it's limited resolution
Do get a DSO though, it complements what you have
« Last Edit: January 11, 2017, 11:56:23 am by JPortici »
Offline ebclr
« Reply #3 on: January 11, 2017, 07:12:01 am »
Based on what you wrote you never touched a DS1054Z, they do far more than you think for less money, It cost effective not a Rolls Roice
LXI itself justify forget analog scopes
Prego
« Last Edit: January 11, 2017, 07:13:34 am by ebclr »
Online ebastler
« Reply #4 on: January 11, 2017, 07:21:16 am »
JPortici -- I am not ready for yet another debate whether the DS1054Z is great or crap... Yes, there is noticeable lag in some user interface operations (e.g. adjusting vertical offset); whether or not that irritates you is very subjective. If at all possible, the OP should try to get his hands on a real DS1054Z to try before he buys.
But please, let's not forget that another fundamental debate along the lines of "cheap DSO or old, upmarket analog scope" is not what the OP asked for at all. He definitely intends to keep his Tek 2467B, and I think that complementing that with an entry level DSO is a perfectly viable option: The analog scope will do a great job in many applications where it is already proven, and the DSO will complement it in applciations where the analog can't go (single shot, rare event etc.).
Offline BravoV
  • +++ ATH1
« Reply #5 on: January 11, 2017, 07:55:06 am »
I currently own a Tektronix 2465B and a 2467B. ....
.. I wanted to buy my first digital oscilloscope.
Well, correct me if I'm wrong, reading above points, I guess you never really realized the true power of DSO which the single shot capture.
This alone sometimes will make even the really good analog scope simply loose it's value against a cheap DSO, especially in a situation where you have to catch a non repetitive glitches.
I'm not an expert, but I sort of understand as I own similar setup with yours on analog side, and currently with these below combination  ;), these both duo are very-very effective and have a really great value when it comes to probing using scopes, imho. (PS : Just ignore the DS1104Z, as its very similar to a "hacked" DS1054Z, or any other "relatively" cheap DSO)
My point is, a good analog + a "relatively" cheap but new DSO offer much more value for the money.
My 1/4 watt resistors worth.
« Last Edit: January 11, 2017, 08:09:11 am by BravoV »
Online tggzzz
« Reply #6 on: January 11, 2017, 08:22:38 am »
...I guess you never really realized the true power of DSO which the single shot capture.
It is surprising how infrequently people understand that. Too often people assume it has to be a zero-sum game when considering analogue vs digital scopes. Horses for courses.
  • Country: br
« Reply #7 on: January 11, 2017, 09:46:13 am »
Thanks for the opinions so far. It seems clear that the new Rigol is a better choice than the old TEK 2440. I will not sell in any way from my 2467B and I am selling 2465B to buy my first DSO as I do not need 3 scopes. My bench is big, the physical size of the scope is not something that worrie
Online tggzzz
« Reply #8 on: January 11, 2017, 10:03:38 am »
... as I do not need 3 scopes...
That's heresy. Wash your mouth out with soap :)
Offline BravoV
  • +++ ATH1
« Reply #9 on: January 11, 2017, 10:04:49 am »
Good decision.  :-+
Another simple question to confirm your choice, what IF ... the newly bought "old" 2440 fails to power up at 2nd day ?
And you running out of luck that the unobtainium chip inside is toasted, even that 2440 is 1/2 the price of new DS1054Z but with warranty.
Will this unfortunate moment makes you unable to sleep easily and not keeping bang your head like this ?  |O   ..... just kidding  >:D
  • Country: br
« Reply #10 on: January 11, 2017, 10:18:05 am »
Good decision.  :-+
The value of TEK 2440 is higher than a new Rigol DS 1054Z. This should seem crazy to anyone who does not live in Brazil (fortunately), since the import of used products is prohibited, tempting offers on Ebay can not be brought to Brazil, as they are seized by federal revenue inspection, unless anyone can Bring some equipment in the luggage on some trip abroad. I paid for Tek 2467B the equivalent of U$ 2500,00! In Brazil we earn very little and we pay dearly!
Offline MrWolf
  • Country: ee
« Reply #11 on: January 11, 2017, 10:23:35 am »
Perhaps. Looking at the specs Tek is 500MSa/s, 1k samples 50s/per division. Also screen seems to be speced as 10bit horizontal electrically. However what Rigol fans would not want you to really understand - DS1054Z it's the only modern scope identified so far that effectively uses only 300 samples for horizontal automated calculations (big selling point of DSO). Take a look at brand new entry level Tek here:
https://www.eevblog.com/forum/testgear/testing-dso-auto-measurements-accuracy-across-timebases/msg1109853/#msg1109853
In this screenshot it uses 187,200 samples. This is different world entirely.
With Rigol most your useful work is fully manual with zoom and cursors and automated measurements only "in the ballbark" in just right timebase. With others all measurements right in at least 3 orders of magnitude "wrong" timebase. So you can track multiple stuff on multiple channels almost like with independent timebases.
So if you actually need to capture large amount of data and analyze it manually (note decoding works only with data on screen - so edges corrupted) then Rigol much better than old Tek. For many other tasks even small memory (50k, 100k etc) modern scope might be better. And probably any other large memory scope will be better. For example entry level Siglent has 70k buffer for calculations and large 14M capture memory in addition. Not Tek but still miles better than Rigol. So you do get what you pay for with Rigol. Nobody sells you $1000 DSO for $400. It really is $400 DSO and even then a bit limited often. If you budget it "frozen" at $400 then what you gonna do... otherwise ;)
Edit: very simple way to think this: DS1054Z ~8x8bit scope. Siglent ~16x8bit scope for automated stuff etc. Dunno whats the limit, but know many scope do various "optimizations" because after ~20x8bit (1M) it getting bit to steep for realtime calculus.
« Last Edit: January 11, 2017, 10:45:44 am by MrWolf »
Offline ebclr
« Reply #12 on: January 11, 2017, 11:03:17 am »
Inventor of the wheel
Discovered that a ferrari is better than a Fiat
But missed that costs 10 times more
Rigol is cost benefit, It's clear Tektronics and keisigth are better, but  10 times mor expensive
Offline MrWolf
  • Country: ee
« Reply #13 on: January 11, 2017, 11:21:28 am »
Siglents do not cost 10x more, also Tek TBS2000 pretty affordable.
Also if you like 1Mpts FFT and well working math look Gw Instek (NB! no decode on entry level!).
Pico dropped prices, currently I see:
PicoScope 2407B 4ch, 64MS memory, $829
PicoScope 2207B MSO 2ch+16ch, 64MS memory, $769
I suspect these use 1M for calculus because FFT is limited to 1M.
(as someone posted these are effectively at least 100MHz analog).
So to get full-blown DSO starting at about 1.5x more (look Siglent deals), not 10x.
« Last Edit: January 11, 2017, 11:30:47 am by MrWolf »
Offline JPortici
« Reply #14 on: January 11, 2017, 11:45:02 am »
Yes that was not what i was aiming at. i did edit the post
« Last Edit: January 11, 2017, 11:58:17 am by JPortici »
Online ebastler
« Reply #15 on: January 11, 2017, 11:51:12 am »
Perhaps. ... DS1054Z it's the only modern scope identified so far that effectively uses only 300 samples for horizontal automated calculations (big selling point of DSO).
Do we really need to go there yet again? The precision of automated measurements may be a big thing for you; but for many others it may be quite irrelevant. Personally, I see a scope mainly as a tool for visualizing waveforms. For me, the "big selling point" of a DSO, i.e. its key advantage over analog scopes, is the ability to look at single or rare events. Automated measurements are just nice to have, and as long as they are as good or better than me eyeballing it on the screen and graticule, I'm happy.
The Tek 2440 is very limited in what I see as the main advantage of DSOs, namely rare event analysis: It gets a whopping 26 waveforms per second, according to what I find on the web. Hence, for me there is no "perhaps" in the decision between a Tek 2440 and any modern DSO, certainly including the DS1054Z.
EDIT: reference added:
But there is no light without shade: The repetition rate is simply disappointing, because the processor and A/D converter are old and slow. In comparison, my 465B displays up to 360,000 waveforms per second, the 2440 only does 26. Not 26,000.
link=https://hohlerde.org/rauch/elektronik/geraete/tek2440/index.en.html
« Last Edit: January 11, 2017, 11:57:24 am by ebastler »
Offline MrWolf
  • Country: ee
« Reply #16 on: January 11, 2017, 12:02:35 pm »
No need :) But please understand every time I hear "just buy" DS1054Z... but OP clearly does not have full picture - he needs to be given full picture to make informed decision. I came to this forum looking for 4x1GSa/s midrange. Bought you know what because endless "just buy". Even people with budget far over 400$ will buy 400$ scope if they think it is as good as 1000$ or even $650. My whole point is this is not the case and is not ethical to give impression that it is, especially if it is made in malicious manner like substituting meanings! "Screen gating" does not equal "screen pixels" etc.
Anyway, think OP has now full info - hopefully can skip battle this time and balanced view is given.
Offline ebclr
« Reply #17 on: January 11, 2017, 12:12:53 pm »
"Siglents do not cost 10x more, also Tek TBS2000 pretty affordable."
Rigol DS1054Z 50MHz 4-Ch Digital Oscilloscope Price: $399.00 ( hackable to 100Mhz )
TBS2072 LIST PRICE US $1,200 70MHz   up to 1 GS/s   20 Mpoints   2
TBS2102 LIST PRICE US $1,460 100MHz   up to 1 GS/s   20 Mpoints   2
TBS2074 LIST PRICE US $1,870 70MHz   up to 1 GS/s   20 Mpoints   4
TBS2104 LIST PRICE US $2,190 100MHz   up to 1 GS/s   20 Mpoints   4
Do you belive that 1870 is affordable comparing to 399 ?
Offline MrWolf
  • Country: ee
« Reply #18 on: January 11, 2017, 12:25:24 pm »
4.7x price diff, not 10x. Geely vs BMW quite normal price diff. Many ppl buy BMW, often used a bit. But can buy Subaru/Mazda etc also, some even turbocharged will smoke unhappy BMW owner ;) Geely probably make to another town also only about hour later  :-DD
Edit: Deep-mem USB DSO - superbike?  :) Not many cows worth of leather and polished alu but goes like bat from hell.
« Last Edit: January 11, 2017, 12:38:31 pm by MrWolf »
Offline djnz
« Reply #19 on: January 11, 2017, 12:29:37 pm »
Which particular oscilloscope is a matter of debate / flamewar, but since you already own an excellent Tek 2467, if I were you, I'd get a modern / modern-ish DSO to complement it.
The following users thanked this post: JPortici
Online Fungus
« Reply #20 on: January 11, 2017, 01:37:46 pm »
If you've got $400 to spend then "just buy DS1054Z" is perfectly valid. You need to spend $1000+ to get something significantly better. That's the part you seem to be missing.
And most of the newbie threads are "I've got a maximum of $400" for some reason (I don't know why, they just are).
The only real alternative at that price is the GW-Instek DS1054B. Half the bandwidth, smaller memory, no serial decoders, poor intensity grading on the display...etc.
As a specialist 'scope for doing audio work or a lot of FFTs then the instek is worth a look. As a general purpose 'scope it falls short of the DS1054Z. In real life the things you need most are high bandwidth and lots of memory for single-shot captures. Your 'horizontal resolution!!' quest is a red herring, sorry.
« Last Edit: January 11, 2017, 01:39:37 pm by Fungus »
Offline MrWolf
  • Country: ee
« Reply #21 on: January 11, 2017, 01:54:30 pm »
Well in my real life do not have to time or will to knob thru megabytes of data manually. So lifes differ. But thats no reason to make incorrect statements as you just did. Counted at least 3. But let you keep them today.
Offline enry68
« Reply #22 on: January 12, 2017, 10:36:42 am »
Hi, I've both Tek2440 and Rigol DS1054Z updated to DS1104Z.
They are two different scopes. I was born with Tek and I love it. But during these years I've seen for the first time a scope that remember to me the Tek: The Rigol. In my lab we have also LeCroy scopes but I prefer the Tek because it is more immediate for the usability. Less menu and more knobs.
Rigol is similar to Tek. imho
So Rigol is cheaper then a used Tek2440 and is younger with new technology. (SW upgradable with a lot of functions) Also other user has wrote about each capability so I can ask to you only one thing: how much money do you want to spend ? 400euros (in Italy) for this scope is a honest price and the quality is good. Remember also that in the 1990 the Tek2440 costs about 30.000.000 Lire --> about 15.000 euros today.
Remember also USB, LAN ..... Tek has the HPIB interface that requires a specific interface in the PC to download or control the scope. (other money if You need to connect the scope to the PC)
So ... to you the choice. ;)
Enrico.
Offline tautech
« Reply #23 on: January 12, 2017, 10:41:39 am »
:-DD
Yeah right. Pull the other one.
Offline enry68
« Reply #24 on: January 12, 2017, 10:43:58 am »
more similar can be appreciated  :P
