Author Topic: Rigol DP832 Question (analog/digital power from same PSU)  (Read 2608 times)
Offline stazeTopic starter
  • I _might_ have a problem...
    • Everybody Staze...
« on: July 22, 2014, 06:46:36 pm »
All,
Thinking about picking on of these Rigol DP832 up, and have a question. Since channel 2 and 3 share a common connection, it seems like the DP832 would not be able to be used to power both the analog and digital side of board in that, I couldn't track with channel 1/2 ±15V, then give 5V to the digital side of things with channel 3, correct? I'd have to run channel 3 to a 5V regulator with, at the lowest, 10V?
Basically, could I get away with having just one bench power supply. =P
Thanks!
“Give a man an answer, he’ll keep his job for a day. Teach a man to Google, and he’ll be employed for a lifetime”
Offline MarcelM
Re: Rigol DP832 Question (analog/digital power from same PSU)
« Reply #1 on: July 22, 2014, 07:09:49 pm »
You can, assuming that you use output 1 for the negative supply, and output 2 for the positive.
Connect the plus side of output 1 to the shared ground of output 2 and 3.
Then you'll end up with -15V, +15V and +5V, which is what I assume you're looking for.
Rgds,
Marcel
Electronics is FUN !
If you want me to take it seriously,
... Call, and we'll talk consultancy rates ...
« Reply #2 on: July 22, 2014, 09:29:22 pm »
Rgds,
Marcel
Okay... weird. I thought for some reason output 3 could only be at most, 5V different than output two, since they share a ground. So then theoretically, I could also do -30V, +30V, and +5V?
Offline MarcelM
« Reply #3 on: July 22, 2014, 09:48:37 pm »
Not just theoretically, you can even do that in practice  :-+
You could also do +60V and +5V, or +30V@6A and +5V
Useful little power supply....
Marcel
« Reply #4 on: July 22, 2014, 09:51:17 pm »
Marcel
Okay then. =) So, what problems do you actually face with regards to the shared common for Channels 2 and 3?
Offline MarcelM
« Reply #5 on: July 23, 2014, 08:31:37 am »
The only issue I can think of, is the way Rigol does current sensing in the (shared) ground connection. EEVBLOG's Dave did a video on this. Best solution is to have a solid ground connection between the ground terminals of output 2 and output 3.
Other than that, the power supply has been performing nicely for me...
Regards,
Marcel
Offline TomThomas
« Reply #6 on: July 23, 2014, 09:41:10 am »
Rgds,
Marcel
if you Need +30 V and  -30V and +5V, why you don't go directly for a DP831??
br Tom
