Could you give us a bit more informations?
Cheers.
Daniel.
Digital version :00.01.09.00.01
Analog Version :00:00:00:00:00:00
boot Version :01.06
Keyboard Version :01.01
Analog version is full of zeros. Depending of where you're living, I can't suggest you to open the box and check the connections as a first step.
Cheers.
Daniel
Should I try upgrading the firmware first ?
I don't think so, but the analog boards, yes.
Cheers.
Daniel
It does not detect the USB stick. Do you have any pictures which connection I sould be looking for
You don't need anything for updating analog boards.
First, press "Help, Help, M4, M2, M1" to update the board1.
Then, press this sequence twice: "M4, M2, M2" to update the board2.
But I'm far from sure that will fix your problem.
Cheers.
Daniel.
Cheers.
Daniel.
Its Fixed. I was just a loose ribbon cable between the analog board and the digital display board.
Thanks for your help Daniel
Cheers.
Daniel.
Nice to read that you fixed the problem :-)
Cheers.
Daniel.
Hi to all,
Maybe someone has firmware rev. 1.10? Don't want to upgrade to 1.11.
Thanks
Why not upgrade to 1.11? It works fine for me.
Oh right - I wouldn't dare try and calibrate it anyway - it comes factory calibrated. If it 'aint broke don't fix it!
Maybe in a year or two...
DEAR GROUP
just unboxed my dp832 it has firmware version 1.10 i tryied using the rigol keygen and it says invalid serial number. Has any body else have this problem. i tryied typing in the generated key several times and used the hi res option and the analiser monitor option. is this version FW locked? do i need to downgrade? any advise or further information I can give you folks please chime in. I will do more research tonight from work thanks in advance
DEAR GROUP
Have you tried options with first letter "F" in keygen? You should use new device options starting from v1.09:
http://riglol.3owl.com/My firmware version was 1.09 and I successfully activated the Hi-Res.
yes used the same link you psted tryied the versions as you suggested starting with F
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
do u think i may have to try to downgrade the FW? How would one go about that on the dp832? Hopefully the bootloader will support that
yes used the same link you psted tryied the versions as you suggested starting with F ![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
do u think i may have to try to downgrade the FW? How would one go about that on the dp832? Hopefully the bootloader will support that ![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
How many digits in the code which you are trying to type?
DEAR GROUP
I've unlocked my DP832, running the same FW, without any troubles (using the Fxxx option codes).
Are you sure about your serial number ?
Cheers.
Daniel.
You cannot downgrade from FW > 1.09
Cheers.
Daniel
I have 1.10 also - and it worked - ensure using correct Riglol - this worked for me:
http://riglol.3owl.com/ - get version data by pressing <Utility> - <SysInfo> - <M1> - <M3> - <M2> - don't use privatekey in riglol
I also have 1.10 and was able to unlock it a couple of weeks ago.
Ulrik
I used the default private key in the key gen software
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
I didn't know I will try the series of keys you suggested. After I press the series of keys you outlined will that give me a different private key?
Thanks
You should use 28 symbols-key (from pop-up window at riglol). Seems you use Privatekey.
So when Ulrik made refrence to the version data and pressing sysinfo m1 m3 m2 what do I do with the information there? When I enter the machines serial # and the options I want the private key is automatically filled in. Then I click generate and it generates a very long alphanumeric string. I type that into the dp832 and it gives me an error. Am I using the key generator correctly or do I use a different private key then click generate? I'm just a bit confused. Sorry
Fill "serial", "options" and click "generate". Type 28-symbols key at the rigol's option->install window. That's all.
<Utility> - <SysInfo> - <M1> - <M3> - <M2> just shows the full system information (bootlader version, etc), I don't know why you need it.
I tryied several times with no luck
![WTF? :wtf:](https://www.eevblog.com/forum/Smileys/default/wtf2.gif)
then I backed out of the keygen program re entered the serial (same as before) generated a new key triple checked (same as before) hit ok expecting "invalid serial #". And POOF "official version installed".
![Clapping :clap:](https://www.eevblog.com/forum/Smileys/default/clap.gif)
I know everything was entered correctly both times maybee regenerating a new key did it. I have a sense of accomplishment even though all I did is enter data. HUGE thanks to all the truely smart helpful folks here that make the real magic happen. THANK YOU ALL.
Attached is the version information of this machine that is to be known as working with the key generator.
Thanks again
