Author Topic: Rigol DP832 - Firmware list and bugs  (Read 320903 times)
0 Members and 12 Guests are viewing this topic.
Offline f1rmb
Re: Rigol DP832 - Firmware list and bugs
« Reply #150 on: September 24, 2014, 11:09:50 am »
Could you give us a bit more informations?
Cheers.
Daniel.
Digital version  :00.01.09.00.01
Analog Version :00:00:00:00:00:00
boot Version    :01.06
Keyboard Version :01.01
Analog version is full of zeros. Depending of where you're living, I can't suggest you to open the box and check the connections as a first step.
Cheers.
Daniel
Offline frahul
  • Country: in
« Reply #151 on: September 24, 2014, 11:31:03 am »
Should I try upgrading the firmware first ?
Offline f1rmb
« Reply #152 on: September 24, 2014, 11:35:44 am »
I don't think so, but the analog boards, yes.
Cheers.
Daniel
Offline frahul
  • Country: in
« Reply #153 on: September 24, 2014, 12:03:58 pm »
It does not detect the USB stick. Do you have any pictures which connection I sould be looking for
Offline f1rmb
« Reply #154 on: September 24, 2014, 12:54:44 pm »
You don't need anything for updating analog boards.
First, press "Help, Help, M4, M2, M1" to update the board1.
Then, press this sequence twice: "M4, M2, M2" to update the board2.
But I'm far from sure that will fix your problem.
Cheers.
Daniel.
Offline frahul
  • Country: in
« Reply #155 on: September 24, 2014, 01:51:59 pm »
Cheers.
Daniel.
Its Fixed. I was just a loose ribbon cable between the analog board and the digital display board.
Thanks for your help Daniel
Offline f1rmb
« Reply #156 on: September 24, 2014, 01:55:32 pm »
Cheers.
Daniel.
Nice to read that you fixed the problem :-)
Cheers.
Daniel.
Offline Jekin
  • Country: by
« Reply #157 on: September 25, 2014, 08:54:07 am »
Hi to all,
Maybe someone has firmware rev. 1.10? Don't want to upgrade to 1.11.
Thanks
Offline Macbeth
« Reply #158 on: September 25, 2014, 07:16:34 pm »
Why not upgrade to 1.11? It works fine for me.
Offline Jekin
  • Country: by
« Reply #159 on: September 25, 2014, 07:21:49 pm »
Because of this bug:
https://www.eevblog.com/forum/testgear/rigol-dp832-firmware-updates-and-bug-list/msg508032/#msg508032
Well, I'm new to the subj. Maybe the manual calibration isn't so important...
Offline Macbeth
« Reply #160 on: September 25, 2014, 07:47:37 pm »
Oh right - I wouldn't dare try and calibrate it anyway - it comes factory calibrated. If it 'aint broke don't fix it!
Maybe in a year or two...
Offline radiogeek97
« Reply #161 on: October 09, 2014, 05:58:06 pm »
DEAR GROUP
    just unboxed my dp832 it has firmware version 1.10  i tryied using the rigol keygen and it says invalid serial number.  Has any body else have this problem.  i tryied typing in the generated key several times and used the hi res option and the analiser monitor option.  is this version FW locked?  do i need to downgrade?   any advise or further information I can give you folks please chime in.  I will do more research tonight from work    thanks in advance
Offline Jekin
  • Country: by
« Reply #162 on: October 09, 2014, 06:03:19 pm »
DEAR GROUP
Have you tried options with first letter "F" in keygen? You should use new device options starting from v1.09:
http://riglol.3owl.com/
My firmware version was 1.09 and I successfully activated the Hi-Res.
Offline radiogeek97
« Reply #163 on: October 09, 2014, 06:20:04 pm »
yes used the same link you psted tryied the versions as you suggested starting with F |O
do u think i may have to try to downgrade the FW?  How would one go about that on the dp832?    Hopefully the bootloader will support that :(
The following users thanked this post: serguletti
Offline Jekin
  • Country: by
« Reply #164 on: October 09, 2014, 06:34:26 pm »
How many digits in the code which you are trying to type?
Offline f1rmb
« Reply #165 on: October 09, 2014, 07:11:46 pm »
DEAR GROUP
I've unlocked my DP832, running the same FW, without any troubles (using the Fxxx option codes).
Are you sure about your serial number ?
Cheers.
Daniel.
Offline f1rmb
« Reply #166 on: October 09, 2014, 07:13:06 pm »
You cannot downgrade from FW > 1.09
Cheers.
Daniel
Offline ulrik
  • Country: at
« Reply #167 on: October 09, 2014, 09:15:22 pm »
I have 1.10 also -  and it worked - ensure using correct Riglol - this worked for me: http://riglol.3owl.com/ - get version data  by pressing <Utility> - <SysInfo> - <M1> - <M3> - <M2> - don't use privatekey in riglol
all circuits lead to ROM
Offline haveissues
« Reply #168 on: October 09, 2014, 09:55:31 pm »
I also have 1.10 and was able to unlock it a couple of weeks ago.
Offline radiogeek97
« Reply #169 on: October 09, 2014, 11:28:25 pm »
Ulrik
   I used the default private key in the key gen software  :palm:  I didn't know   I will try the series of keys you suggested. After I press the series of keys you outlined will that give me a different private key?
Thanks
Offline Jekin
  • Country: by
« Reply #170 on: October 10, 2014, 06:49:04 am »
You should use 28 symbols-key (from pop-up window at riglol). Seems you use Privatekey.
Offline radiogeek97
« Reply #171 on: October 10, 2014, 07:30:15 am »
So when Ulrik made refrence to the version data and pressing sysinfo m1 m3 m2 what do I do with the information there? When I enter the machines serial # and the options I want the private key is automatically filled in.   Then I click generate and it generates a very long alphanumeric string. I type that into the dp832 and it gives me an error.     Am I using the key generator correctly or do I use a different private key then click generate?    I'm just a bit confused.      Sorry
Offline Jekin
  • Country: by
« Reply #172 on: October 10, 2014, 07:36:11 am »
Fill "serial", "options" and click "generate". Type 28-symbols key at the rigol's option->install window. That's all.
<Utility> - <SysInfo> - <M1> - <M3> - <M2> just shows the full system information (bootlader version, etc), I don't know why you need it.
Offline radiogeek97
« Reply #173 on: October 10, 2014, 02:35:05 pm »
I tryied several times with no luck  :wtf:  then I backed out of the keygen program re entered the serial (same as before) generated a new key triple checked (same as before) hit ok expecting "invalid serial #".  And POOF "official version installed".   :clap:    I know everything was entered correctly both times maybee regenerating a new key did it.     I have a sense of accomplishment even though all I did is enter data.  HUGE thanks to all the truely smart helpful folks here that make the real magic happen.    THANK YOU ALL.
Offline radiogeek97
« Reply #174 on: October 10, 2014, 02:37:50 pm »
Attached is the version information of this machine that is to be known as working with the key generator.
Thanks again
