Author Topic: Rigol DP821... Good high Amp PSU ? And do the 'upgrades' work same as the DP832  (Read 1620 times)
Offline ozadr1anTopic starter
Hi All,
I'm about to consider getting the DP821, because I often need a bit more than 3A. Does the usual .ca site key's work the same on upgrading the DP821 ? It unfortunately only lists the DP832 specifically, and searching around, I can't find any details on the DP821..
Any tips, pointers, or experience from other 821 users much appreciated :)
Thanks
Adrian
