Ok, my long time logging session is over!
I'm currently opening my DM3061 up. I shall shoot some photos but I can already say my unit doesn't look bad at all. I already identified the proper caddock resistor network and not seen any bad soldering or flux.
One question: How to identify the voltage reference? I see no metal TO-46 so I suppose it's in a SO8? I have higher resolution pictures available, so if someone wants a zoom in on a particular area, please tell. A couple of SOs are sanded, I assume they may be ADCs and voltage reference and such.
The bottom side of the PCB contains no components whatsoever. No remarks there.
I'm quite happy. I was worried for days that my trusted DM3061 was not so trustworthy, but I think its in the clear now.
Edit: Info from the utility menu:
Model: DM3061
Serial: DM3D115000887
Version: 03.12.00.03.09.00
CAL temp: 23C
I'm very happy with my DM3061 and I have used it heavily under my 1.5 years of ownership. I never turn my unit off on the back switch, only the "soft off" on the front panel. I use it for long time logging, and I like the stat functions.
I have only one big complaint: The null mode is somewhat retarded. I prefer a conventional "relative" mode. If I use the null mode, the DM3061 put itself in some sort of autoranging mode, even if you clearly has selected a fixed range. Its probably deliberately made this way, but I don't like it and I cannot really use it as a rel mode.
As I said before, I don't have any DMMs that can match the 2 400 000 counts, so I can only check the stability with my 100 000 counts Fluke 45 and my 210 000 counts Thurlby Thandar 1906 "computing multimeter" (thats TTi, is it not?). They all agree pretty much, but sometimes one of those three show a few LSB counts different. Hard to know witch is nearest the "reality" or most stable over time and temperature. But my faith in DM3061 is restored!
