Author Topic: Rigol DM3058 Continuity Buzzer  (Read 2263 times)
Offline 45OverloadTopic starter
« on: May 04, 2016, 08:02:48 pm »
Confirmed with Rigol that the DM3058 continuity and diode check noise is an annoying grunt sound instead of a higher pitched beep that most of us are used to.  If anyone has snooped around inside a 3058 and found the source of this ugly noise, I'd be interested to know more.  Naturally, the 3068 does not do this...what were they thinking?  I would be nice if something in the fw could fix it.  Otherwise we are stuck with a near useless faint pack-man error sound.
45
Never fix that which is not broken.
Online Fungus
Re: Rigol DM3058 Continuity Buzzer
« Reply #1 on: May 05, 2016, 06:56:29 am »
This thread is useless without an audio recording.  :popcorn:
« Last Edit: May 05, 2016, 07:42:31 am by Fungus »
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #2 on: May 05, 2016, 07:16:06 am »
I found one sample in a video and it does sound rather awful, I had to crank up the volume.   :-//
https://www.youtube.com/watch?v=TxN6DJg5fsk&feature=youtu.be&t=134
Online Fungus
« Reply #3 on: May 05, 2016, 06:16:57 pm »
Sounds more "Frogger" than "Pacman" to me.
The only hope is if it's done using a buzzer with built-in oscillator. You can get a new buzzer with a different frequency.
If it's done in software then you'll need to patch the firmware (which is be a whole project in itself).
Or ... maybe you could put an Arduino inside to detect voltages on the buzzer and shift the frequency.  :popcorn:
Offline jord4231
« Reply #4 on: April 07, 2020, 02:08:01 am »
Did you ever do anything about that pesky buzzer I know this is an old thread but man its anoying as!
