Tested Rigol DL3021A unit with 12.5V 2A DC supply and 1.1 A load current in battery app mode. ON/OFF gives either 1.1 A or 0.0149 A load current - result is random, more times gives correct 1.1 A value. Incorrect load is always the same, 0.0149 A. Final load current is stable, but 0.0149 A goes back to full 1.1 A if current setting is changed by minimal increment as shown in @stewart.nz's video above.
Not sure why that happens, did not check in more detail with scope.
It is clearly a bug and needs fixing.
SW ver. 00.01.05; FPGA ver. 01.02; boot ver. 01.011
