Author Topic: Rigol DHO924S bandwidth measurement  (Read 548 times)
Offline juhandTopic starter
  • Country: hu
« on: July 01, 2024, 03:27:51 pm »
Hi, I made a Rigol HDO924S bandwidth measurement.
I used R&S SMB100A signal generator for source, and I calibrated with a R&S URV35.
I used 0 dBm @ 50ohm, that is
sqrt(50*10^0/1000)=224mVrms
sqrt(50*10^0/1000)*sqrt(2)*2=632mVpp
and I set the oscilloscope to 200mV/div.
« Last Edit: July 01, 2024, 03:32:16 pm by juhand »
The following users thanked this post: egonotto, Fungus
Offline TimFox
Re: Rigol DHO924S bandwidth measurement
« Reply #1 on: July 01, 2024, 03:28:58 pm »
And the answer was?
Online egonotto
« Reply #2 on: July 01, 2024, 03:47:30 pm »
The following users thanked this post: juhand
Online Fungus
« Reply #3 on: July 01, 2024, 05:19:50 pm »
My DHO804 measures at about 280Mhz when I tell it to be a DHO924.
nb. I did it via a rise time calculation, I don't have a 300MHz signal generator.
Offline J-R
« Reply #4 on: July 03, 2024, 08:39:48 pm »
Maybe pick up a tinySA Ultra?
Online Martin72
  • Testfield Technician
« Reply #5 on: July 03, 2024, 09:44:36 pm »
It depends on how linear the thing itself is.
(Kierkegaard)
Offline TimFox
« Reply #6 on: July 03, 2024, 11:01:07 pm »
The usual (BW) x (Tr) = 0.35 formula for rise time vs. -3 dB bandwidth is not valid in general:  it depends on the shape of the low-pass filter function.
For the typical amplifiers used in analog oscilloscopes, it is reasonably accurate.
The following users thanked this post: Markus2801A
Online Martin72
« Reply #7 on: July 03, 2024, 11:30:19 pm »
For most new scopes, you have to use 0.4....0.45 in the formula.
This was the case with the DHO800 when I first measured the risetime and then the bandwidth with an R&S SML01.
(Kierkegaard)
The following users thanked this post: egonotto, Markus2801A
Online Fungus
« Reply #8 on: July 04, 2024, 01:53:26 am »
I used 0.45 in my calculation. I'm not going to argue 100% correctness but it gives a much better answer than 0.35 when applied to these devices. Definitely in the right ballpark.
FWIW: Other people have measured the bandwidth of these 'scopes using signal generators and all got numbers in the 280-300Mhz range when they're configured as a DHO924.
My measured bandwidths using rise time calculation on a hacked DHO804:
DHO804 125Mhz      (70MHz sticker)
DHO814 200Mhz     (100MHz sticker)
DHO914 225Mhz     (125MHz sticker)
DHO924 280Mhz     (250MHz sticker)
