Author Topic: Rigol DHO804 Test and Compare Thread  (Read 153528 times)
0 Members and 12 Guests are viewing this topic.
Online Martin72Topic starter
  • Testfield Technician
Re: Rigol DHO804 Test and Compare Thread
« Reply #900 on: November 18, 2023, 03:05:50 pm »
You could say that, Thank you Lecroy  ;D
(Kierkegaard)
The following users thanked this post: voltsandjolts
Online zrq
Noise characterization
« Reply #901 on: November 18, 2023, 03:47:06 pm »
I did some characterization of the input voltage noise of my DHO914S (250 M BW unlocked) at the full sampling rate (1.25 Gsps). Input shorted and scope is warmed up for ~1 hour.
1931637-0
The following users thanked this post: thm_w, s3t, Martin72, Serg65536, UK
Online DaneLaw
« Reply #902 on: November 19, 2023, 12:41:39 am »
DHO800 it's OK as functionality, but the effective screen size is very small. The all-time active menus takes a lot of space. 10 inch is much better for this interface.
Also, the USB-C power supply connector it's not on my taste.
Yep. the DHOxxx vertical-screen aspect is undermined quite a bit by menus & info boxes..
From users-screenshots, it looks to be up around 35%?  That's a lot of your precious" vertical screen when you're dealing with a 7" that is in a 16/9 ratio that is already vertically cramped if you can't remove some of these top & bottom boxes.
Offline Fungus
« Reply #903 on: November 19, 2023, 12:48:18 am »
It's easy to imagine that but I bet you won't even think about it after you use one for a few weeks.
You really have to see one in person to appreciate the tiny size.
Ditto.
But this 'scope does a lot of things horizontally.
« Last Edit: November 19, 2023, 12:50:22 am by Fungus »
« Reply #904 on: November 19, 2023, 01:09:14 am »
The DS1000Z wastes more space in the display, so in general you can either get by with the 7" or not.
Exactly that.
I've often said elsewhere that it makes a difference whether you try something out yourself or just read about it, look at pictures and watch videos... ;)
(Kierkegaard)
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #905 on: November 19, 2023, 03:44:12 am »
screen is small if you want read pdf with it, but its not a pdf reader. once you try to debug a real circuit, even 4" screen is better than none at all.most reviews are imho only aeshetic or try to compare it with 27" screen entertainment machine.
Offline NE666
« Reply #906 on: November 19, 2023, 08:58:58 am »
See my post in the suitable thread, this is a sale of the old designations, I don't think it means anything more.
Plausible but I'd be more secure in that belief if it were not for the announcement of the 1000U model.
Might it not be the case that lower than expected sales revenue from the 1000 series has forced Rigol to look at its BOM cost, being just a DAC short of the considerably more expensive 4000, the result being the cost-reduced 1000U which will ultimately replace it in the product line?
Just a theory but the product line is starting to look very crowded already without yet another low-end 12-bit.  FWIW the signal generator range seems to be suffering the same, with the 800/900 Pro announcement.
Online ebastler
« Reply #907 on: November 19, 2023, 10:12:27 am »
800/900 Pro? Would you have a link?
Offline bulba99
Online ebastler
« Reply #909 on: November 19, 2023, 11:15:33 am »
Ah, thank you. I had misunderstood and thought you were talking about the internal signal generators in the scope, and an upcoming change in their voltage or frequency range.
« Reply #910 on: November 19, 2023, 09:32:35 pm »
I have just had another go at decoding, this time feeding in the signal(SPI) from the competitor's demoboard. >:D
After a few attempts, I managed to get a super-stable signal.
First with 3 channels, so CS included.
I used the "Pulse" trigger.
Then I looked to see if I could do the same with 2 channels and timeout.
Yes, but a few letters were missing, the solution was that the default timeout is 1µs, 8µs was then enough.
Finally I tried it with the SPI trigger.
This also enabled me to create a rockstable trigger with a timeout of 8µs.
Interesting:
In the SPI trigger menu you can only select MISO, but I had previously deactivated MISO in the decoder menu because it is not available on the demo board (only MOSI).
Conclusion:
The decoder signals on the siglentboard are also "bitchy"(like on the batronix board), but with the right settings the DHO achieves super stable decoding - very good. :-+
« Last Edit: November 19, 2023, 09:39:06 pm by Martin72 »
(Kierkegaard)
The following users thanked this post: thm_w, Fungus, ebastler, tiagoalecio
Online ebastler
« Reply #911 on: November 19, 2023, 09:48:49 pm »
Hi @Martin72, I came across a thread in the German mikrocontroller.net forum a while ago which discusses I²C decoding on the MSO5000. It is claimed there that the MSO5000 can only decode reliably when it does a surprisingly high amount of oversampling: Sampling at 50x the I²C bit rate is supposedly not enough for reliable decoding, 100x works.
That observation seems very surprising to me, and I am not sure it is correct. The modest DS1054Z -- while being very limited by the fact that it only decodes from screen memory -- can at least do that nicely as soon as it can resolve the bits in the I²C signal. Could you try with the DHO800 which degree of oversampling it needs, by either limiting the memory size or zooming out to a very slow time base? Thanks!
« Reply #912 on: November 19, 2023, 10:04:41 pm »
Can do it tomorrow with the batronix demoboard (I²C does not work on the siglent demoboard).
(Kierkegaard)
The following users thanked this post: ebastler
« Reply #913 on: November 19, 2023, 10:52:37 pm »
Can do it tomorrow with the batronix demoboard (I²C does not work on the my siglent demoboard).
FTFY  ;)
« Reply #914 on: November 19, 2023, 10:55:37 pm »
Hehehe.... ;)
(Kierkegaard)
« Reply #915 on: November 20, 2023, 07:05:40 pm »
I tested it with 20kbit data rate.
20KSa/s is too low, nothing is decoded.
It has to be 50Ksa/s to display anything meaningful.
However, you can't always play with the manual memory, everything under 1Mpt is dropped from 200ms/s.
Since the batronix board offers different data rates, I will probably test another, higher speed.
(Kierkegaard)
Offline Fungus
« Reply #916 on: November 20, 2023, 07:09:10 pm »
Well, obviously...
20kbit data rate means the clock signal is changing 40k times per second.
How will you capture that with 20kSa/s?
Working at 50kSa/s is quite impressive. It's only 20% above the minimum requirement.
(and the "minimum" still means you have to get lucky with the sample alignment)
« Last Edit: November 20, 2023, 07:11:16 pm by Fungus »
Online ebastler
« Reply #917 on: November 20, 2023, 07:15:50 pm »
Agreed, that's a pretty convincing implementation.  :-+
Thank you for testing, Martin!
« Reply #918 on: November 20, 2023, 08:39:42 pm »
It was only for demonstration... ;)
See the previous question from ebastler.
(Kierkegaard)
« Reply #919 on: November 20, 2023, 09:01:43 pm »
Now the data rate has been increased from 20kbits to 200kbits.
It needs 500KSa/s to decode this properly, very good.
I noticed this briefly when I was playing around earlier(with the lower datarate), but didn't go into it.
Now I noticed it again:
2.5MSa/s flawless decoding
1.25MSa/s NO decoding
500KSa/s flawless decoding again.
Interesting....
(Kierkegaard)
Online ebastler
« Reply #920 on: November 20, 2023, 09:12:54 pm »
Interesting....
I'd say that is another entry for the bug thread.  :-BROKE
Some of the addresses are still decoded correctly at 1.25 MSa/s (but most of them are not). But not a single letter? What does it look like if you zoom in, so that individual characters can be displayed on the decoder trace?
« Reply #921 on: November 20, 2023, 09:46:41 pm »
Nothing gets better, I think because of the scarce 100Kpts.
But:
As usual, 1.25MSa/s, 5ms/div. nothing is displayed correctly.
Then press stop and increase to 10ms/div - now it is displayed correctly.
It gets even better, back to 5ms nothing displayed, then to 2ms...it is displayed correctly.
(Kierkegaard)
Online ebastler
« Reply #922 on: November 20, 2023, 10:04:47 pm »
:o
« Reply #923 on: November 23, 2023, 07:11:45 pm »
An old friend has found his way here. ;)
(Kierkegaard)
Online ebastler
« Reply #924 on: November 23, 2023, 07:18:50 pm »
Looks a bit yellowish-stained in comparison... And I guess it will look old in many other ways too.  ;)
