Author Topic: Rigol DHO804 Test and Compare Thread  (Read 140402 times)
RogerG and 10 Guests are viewing this topic.
Offline TurboTom
Re: Rigol DHO804 Test and Compare Thread
« Reply #175 on: October 13, 2023, 08:48:17 pm »
Yeah of course but in a new design in this day and age a single USB A port is just plain being mean. It's not like there isn't any realestate to have added more.
Not true in case of the DHO900 where the digital probe connector takes up all the space between the USB host port and CH1 BNC. And the '800 and '900 share the same PCB. But it should have been possible to place another USB host connector at the rear.
Offline ebastler
« Reply #176 on: October 13, 2023, 08:49:04 pm »
I still haven't managed to update my firmware.  >:(
I know the USB stick works because I can see in the file manager.
Have you tried a different USB stick anyway, not too large, freshly formatted with FAT32, nothing else in the root directory?
I recall that this has historically been an issue with other scopes. And there were a couple of posts here relating to the DSO800 DHO800, with one user experiencing software freezes when saving files to USB, while it worked fine for someone else.
« Last Edit: October 13, 2023, 08:57:18 pm by ebastler »
Offline ebastler
« Reply #177 on: October 13, 2023, 08:53:02 pm »
A new update is avaible ?
Yep, see here: https://www.eevblog.com/forum/testgear/rigols-new-dho800-oscilloscope-unbox-teardown/msg5109042/#msg5109042
Some users have reported that a couple of fixes not mentioned in the release notes were also made, e.g. the "crash when turning the encoder past a certain value" thing.
Online Fungus
« Reply #178 on: October 13, 2023, 08:55:26 pm »
Yes!
https://www.eevblog.com/forum/testgear/rigol-dho914s-bode-plot/msg5109180/#msg5109180
(unless it's just a cruel joke...)
nb. The Bode Plot isn't fixed.
Offline ebastler
« Reply #179 on: October 13, 2023, 08:56:21 pm »
I guess it's a market segmentation thing. A second USB host port is clearly a feature found only in midrange scopes, never mind the fact that it only costs 30 cents to add.  ::)
Online Martin72Topic starter
  • Testfield Technician
« Reply #180 on: October 13, 2023, 09:02:26 pm »
v00.01.01.00.01  2023/08/10
1. Remove all time-related displays on the instrument
2. To modify the vertical interface, click the wiring diagram to modify the AC coupling function
3. Modify the delayed scan Chinese display as Zoom
4. Modify the order of the menu in the upper right corner, put the measurement in the front and Default in the back
5. The probe ratio interface is removed, and the probe ratio option is added to the vertical first-level menu
Hm, ok I´ll try it now.
(Kierkegaard)
Online Fungus
« Reply #181 on: October 13, 2023, 09:12:45 pm »
The HDO1000 has three and it's the exact same chipset.
« Reply #182 on: October 13, 2023, 09:13:44 pm »
Define a midrange scope.  :P
« Reply #183 on: October 13, 2023, 09:14:09 pm »
Upgrade done.. ;)
(Kierkegaard)
Online Fungus
« Reply #184 on: October 13, 2023, 09:18:10 pm »
Upgrade done.. ;)
Let me download that file again...
Offline LonnieU
« Reply #185 on: October 13, 2023, 09:21:22 pm »
I spent several minutes there....
You have to select (check) the circle to the right of the filename. Then it will show up in the "Upgrade" window.
Offline ebastler
« Reply #186 on: October 13, 2023, 09:22:32 pm »
10" screen, price close to or above 1000€, multiple USB ports.  ;)
Naming of the ranges is debatable, of course. But the manufacturers seem to agree that their entry-level scopes are characterized by a 7" screen, a price tag in the mid-3-digits, and apparently a single USB port.
Offline LonnieU
« Reply #187 on: October 13, 2023, 09:23:38 pm »
Upgrade done.. ;)
« Last Edit: October 13, 2023, 09:25:18 pm by LonnieU »
« Reply #188 on: October 13, 2023, 09:27:20 pm »
Nearly, $499 7" display 4ch X-E has 2x USB A, one front, one rear.
Also $639 7" display 200 MHz 2 GSa/s SDS2202X-E same ^
« Last Edit: October 13, 2023, 09:37:18 pm by tautech »
The following users thanked this post: ebastler
« Reply #189 on: October 13, 2023, 09:28:49 pm »
Yepp....
After checking the circle press OK.
(Kierkegaard)
Online Fungus
« Reply #190 on: October 13, 2023, 09:43:19 pm »
Upgrade done.. ;)
Oh...
You have get the .gel file name in the input box.
In the instructions it says "copy the file into the root folder..." and I thought that was enough (it always was in the past on other 'scopes).
I got it to work now.  :-BROKE
Online Fungus
« Reply #191 on: October 13, 2023, 09:46:41 pm »
Update: I just noticed one of my USB sticks is NTFS and it was working just fine in the 'scope.
« Reply #192 on: October 13, 2023, 09:49:06 pm »
I must confess before finding it out what the circle means, I´ve copied the file to the local disk and then did the upgrade.. ;)
Confirmed, last is really useful.
(Kierkegaard)
« Reply #193 on: October 13, 2023, 09:54:07 pm »
Do show the range of probe attenuation available and any custom attenuation, if available.
« Reply #194 on: October 13, 2023, 10:10:05 pm »
Sir, yes Sir !  ;)
More than enough to select.
(Kierkegaard)
« Reply #195 on: October 13, 2023, 10:11:39 pm »
Sir, yes Sir !  ;)
Custom ?
How many ?
Offline ebastler
« Reply #196 on: October 13, 2023, 10:12:53 pm »
Custom ?
How many ?
None. Put it on the Siglent sales pitch list.  :=\
« Reply #197 on: October 13, 2023, 10:16:42 pm »
Custom ?
How many ?
There is no such thing, and with 28 options, you don't need it.
For example, we have many differential probes with 200x, 500x, 1000x and even 1500x.
And we have mostly scopes that "offer" only 3 fixed ratios, I find manual input annoying, such a selection as the DHO offers it more practical.
(Kierkegaard)
« Reply #198 on: October 13, 2023, 10:26:32 pm »
Custom ?
How many ?
There is no such thing, and with 28 options, you I don't need it.
Correction made.  :P
Hmmm, use 100x and 1000x passive probes here which of course there should be selections for and as you say differential probes offer many different attenuations as do current probes.
However when working with shunts one does need custom attenuation which it seems Rigol has not allowed for.  :-BROKE
Online Fungus
« Reply #199 on: October 13, 2023, 10:44:41 pm »
Uh, oh!
Is somebody compiling a new Rigol vs. Siglent comparison chart?
