Author Topic: Rigol DHO800/900 Oscilloscope Bug Reports + Firmware  (Read 280163 times)
Offline Fungus
Re: Rigol DHO800/900 Oscilloscope Bug Reports + Firmware
« Reply #675 on: June 28, 2024, 02:00:12 am »
Just checking: You do have your probe attenuation set to 1x on the 'scope, right?
No. 10x on the probes, 10x on the probe settings. Is there some reason why I shouldn't be doing that for decoding?
It's a well-known bug in the decoders. You need to set 1x attenuation on the 'scope or the decoder threshold voltage is wrong (10x too small).
(keep the switch at 10x on the probes, obviously)
Offline Howardlong
« Reply #676 on: June 28, 2024, 06:57:24 am »
I can't tell if you're joking or not?
Online csuhi17
  • Country: hu
« Reply #677 on: June 28, 2024, 08:15:26 am »
I ran several test with the threshold voltage and found that it is the threshold voltage scale issue. If I set the probe to X1 scale then everything works fine but with the X10 probe scale does not work because  the actual threshold voltage 10 times less than I set. But if I increase the threshold voltage 10 times (10V instead of 1V) then decoding starts again.
Yep. I received my 'scope today and serial decoding only works when the probes are set to 1x.
Edit: This is NOT fixed in the 1.01 firmware.
Fnirsi oscilloscope = waste&regret
Offline Fungus
« Reply #678 on: June 28, 2024, 08:32:44 am »
This bug has been discussed many times here...  :-//
It's been on the bug list since at least November:
https://www.eevblog.com/forum/testgear/another-bug-in-the-rigol-dho914sdho924s-bode-plot-feature/msg5184534/#msg5184534
It's supposedly fixed in the DHO1000 since a few weeks ago.
(last item in the changelog)
https://www.eevblog.com/forum/testgear/new-rigol-hdo1000-12-bit-dso-bugs/msg5553587/#msg5553587
« Last Edit: June 28, 2024, 05:30:52 pm by Fungus »
Offline Howardlong
« Reply #679 on: June 28, 2024, 10:45:14 am »
I honestly don't know what to say, other than to reiterate that this scope is an ornament, and it will remain so until the firmware comes out of alpha.
I'd already run out of patience with this scope half a dozen times before, with rose tinted glasses thinking it can't be that bad. Every time it's been a disappointment.
No one should be considering purchasing this scope with its current firmware state, unless they like adorning their bench with ornaments.
The following users thanked this post: petrinch
Offline rpro
« Reply #680 on: June 28, 2024, 12:34:22 pm »
I just tried it with the Batronix demo board and 10x on probes and scope are working fine with I2C (DHO800).
Offline Fungus
« Reply #681 on: June 28, 2024, 03:19:34 pm »
It can work on 10x but your signal has to go all the way to zero.
If there's even a tiny offset (eg. 0.2V) due to probing or whatever then you can get caught out by this bug.
Setting probe to 1x makes sure.
The following users thanked this post: rpro
Offline Fungus
« Reply #682 on: June 28, 2024, 05:36:07 pm »
It was literally being discussed in the post you originally quoted.
nb. I'm not name-calling, we all miss stuff, but this bug has been discussed endlessly here.
Offline Howardlong
« Reply #683 on: June 28, 2024, 05:47:16 pm »
As I already stated, I've already wasted enough time on this scope and its litany of bugs. When there's a new firmware release I'll revisit.
Until that time, anyone considering purchasing a scope should avoid this one.
The following users thanked this post: lunix
Offline Lathe26
« Reply #684 on: July 07, 2024, 12:59:26 am »
Multiple bugs / limitations that make it hard to save / export Logic Analyzer data, at least with the v01.02.00.02 firmware:
  • WFM file format only supports saving analog data.  It doesn't save digital data from the LA, even though the UI makes appear this is possible.  This was uncovered while decompiling the libscope-auklet.so file while reverse-engineering the WFM file format.  Unclear whether this is a bug or limitation of the file format.
  • BIN file format supports saving digital data and analog data.  However, due to a bug, BIN files can only be successfully saved if both the LA and a CH are active.  If only the LA is on, then the BIN file's header will be written but LA data is missing.  On the upside, the BIN file format is well documented in the DHO800/900 User Guide PDF.
  • CSV file format supports saving digital-only, analog-only, and digital+analog.  The file format is easy to read.  The only downside is the large file size and how slow large samples takes to write to disk.
  • SCPI support for retrieving digital data is broken.  Setting the source to a D0 thru D15 channel fails (e.g., ":WAVeform:SOURce D0").  The scope displays "Remote Cmd Execute Error" on its screen.  Querying ":SYSTem:ERRor?" often returns "-200,"Command execute failed" and querying ":WAVeform:SOURce?" always returns the previous setting.
Anybody know of work-arounds or additional ways to save / export LA data?
Offline joe500
« Reply #685 on: August 03, 2024, 02:58:18 pm »
Hello community! Im Happy with my DHO914s so far. But when I tried to decode a simple spi message the scope would not show anything. I've set Mosi, CLK and CS. I've the open source digital interface. As can be seen in the picture the spi message gets picked up perfect but no decoding is happening. Is this a bug or am I missing out on something?
Offline Howardlong
« Reply #686 on: August 04, 2024, 04:30:32 pm »
SPI decode doesn't work on the LA channels. See post #124. It's a bug that's never been addressed in any public firmware release.
« Last Edit: August 04, 2024, 04:32:10 pm by Howardlong »
Offline TomKatt
« Reply #687 on: August 04, 2024, 07:44:42 pm »
Seems like decoding LA channels would have been basic QA testing?  And not only did that bug get through testing, but is still unresolved?  Sometimes it feels like the VESA mount got more attention than the firmware…
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
The following users thanked this post: joe500, Howardlong, shapirus
Offline joe500
« Reply #688 on: August 05, 2024, 06:04:53 am »
That's a real bummer  :palm:. But thank you for the clarification  :-+
Offline Howardlong
« Reply #689 on: August 05, 2024, 08:16:24 am »
Not least because this exact use case is exceptionally common on an MSO, leaving the analogue channels available to probe around other time-correlated stuff.
Offline Aleksandr
  • Country: ru
« Reply #690 on: August 07, 2024, 01:50:00 pm »
By the way, here is an example of work I2C. And it works somehow.
Offline Howardlong
« Reply #691 on: August 07, 2024, 08:04:17 pm »
Yes, I2C does work on the LA.
For SPI, there is a lot wrong with the decoder dialogue box with the LA such as it asks for things like threshold voltages on LA channels. It's likely that feeds into the issue where it appears just not to work.
The SPI LA issue alone means it stays in the cupboard.
Disappointing is that there's no evidence Rigol are interested in fixing this, or a multiplicity of other issues that show themselves within an hour or two of using it.
The MSO5000 I sometimes have on the bench is, apart from a few relatively minor irritations that I can bear with, far better in comparison. (Although I had a repeating issue with a regulator blowing on the main board, covered elsewhere: I now have a replacement unit now with a 3 year guarantee).
Offline artmau
« Reply #692 on: September 03, 2024, 10:58:25 am »
My DHO804 is not booting. Today, after pressing power button the other buttons light up for a moment (as usual) and than there is only a black screen. Tried two different power supplies.
Do you guys have any ideas?
Offline RogerG
« Reply #693 on: September 03, 2024, 11:35:09 am »
is there any device in the front USB port?
The following users thanked this post: artmau
Offline artmau
« Reply #694 on: September 03, 2024, 12:23:20 pm »
Poking SD card through the vent hole helped!
Online csuhi17
  • Country: hu
« Reply #695 on: September 03, 2024, 12:36:02 pm »
if I remember correctly, you have to wait a long time for it to load, it happened to me once, I set something wrong.
I am not exactly sure what you're seeing.  But I thought I had bricked mine (DHO924S) at one time, as it wouldn't start the scope app in Android.  I unplugged everything, and left it overnight (about 10-12 hours). Then it worked again.  I will say, I have never seen such a buggy piece of test equipment.
« Last Edit: September 03, 2024, 12:58:48 pm by csuhi17 »
Offline norbert.kiszka
« Reply #696 on: September 03, 2024, 01:33:52 pm »
IMHO writing same question in many different posts/places makes a mess in a forum/internet. It's better to not doing it, unless You didn't receive answer for a long time or this is a life or death situation.
Offline mouz
  • Country: pt
« Reply #697 on: September 03, 2024, 03:39:14 pm »
Is it just me that thinks that putting the OS on a SD card is a bad idea ? Especially when the device isn't used on a daily/weekly basis.
if you squint it's mint
« Reply #698 on: September 03, 2024, 06:50:40 pm »
When I was doing research and completely new software for this scope, I was removing and putting back SD card literally hundreds times. From time to time, this cheap socket has some issues with connection. In that case, one remove and put it back always was enough (unless I had bug in a bootloader code or configuration).
Offline Brambolinie
    • Greendome Tech
« Reply #699 on: September 05, 2024, 08:10:58 pm »
RIGOL just released a software update, hopefully it fixes some stuff like the LA channels not decoding SPI
