Author Topic: Rigol DHO800/900 Oscilloscope Bug Reports + Firmware  (Read 282655 times)
gabiz_ro, emi91 and 9 Guests are viewing this topic.
Offline Martin72
  • Testfield Technician
Re: Rigol DHO800/900 Oscilloscope Bug Reports + Firmware
« Reply #100 on: November 12, 2023, 11:16:48 am »
I have never had that behavior here.
What I have just found:
After a restart, the decoder function is switched off, you have to reactivate it.
At least the last values set there are retained.
(Kierkegaard)
The following users thanked this post: Fungus
Offline Fungus
« Reply #101 on: November 12, 2023, 11:49:31 am »
I get the feeling it's related to another setting. Let's see if it was the wave intensity. I remember setting that to 100% and I forgot to put it back afterwards.
PS: Is your transparency the same as your wave intensity?
Offline Martin72
« Reply #102 on: November 12, 2023, 12:06:03 pm »
I think not, could check this later..
(Kierkegaard)
Offline Martin72
« Reply #103 on: November 12, 2023, 06:18:54 pm »
What the...
I´ve set the transparency to 50%, wave intensity 70%, then restart...
Transparency is now 66%... :scared:
(Kierkegaard)
Offline Fungus
« Reply #104 on: November 12, 2023, 08:03:21 pm »
What the...
OK, I've been playing.
When you reboot it: The window transparency is set to whatever the wave intensity was when it booted up.
eg. Boot up with wave intensity=80% then set wave intensity to 20%
On the next boot the transparency will be 80%.
On the boot after that it will be 20%.
So if your wave intensity is 70% or something like that you'll never notice. I only noticed because I had it at 100%.
There's definitely something wrong with state save/restore for some parameters (most are fine).
I'm guessing they're the parameters at the end of the state file and there's a missing/extra item in the save compared to the load.
(or an item with a different size...something like that)
« Last Edit: November 12, 2023, 08:05:40 pm by Fungus »
The following users thanked this post: Serg65536
Offline Fungus
« Reply #105 on: November 12, 2023, 08:08:03 pm »
Update: I just pressed the "DEFAULT" button and the waveform intensity and window transparency were set to 50%, that's why nobody else noticed it.  :)
« Last Edit: November 12, 2023, 08:12:41 pm by Fungus »
Offline Fungus
« Reply #106 on: November 12, 2023, 08:10:51 pm »
The bug where it doesn't save the setting for Fine/Zoom mode is probably related to this one...
Offline Martin72
« Reply #107 on: November 12, 2023, 08:13:32 pm »
I just pressed the "DEFAULT" button and the waveform intensity and window transparency were set to 50%.
Hm,
there seems to be something wrong with the power on state routine which you mentioned earlier.
That's why I never noticed it before, because I had the power on state set to "default" the whole time, until I didn't feel like setting everything up again after every start.
(Kierkegaard)
Offline Fungus
« Reply #108 on: November 12, 2023, 08:23:12 pm »
OK, steps to reproduce this:
1) Enable "Load last" in the setup
2) Set "Wave Intensity" to 100% in the Display settings.
3) Reboot twice.
You now have 100% transparency in the overlay dialogs.
Online ebastler
« Reply #109 on: November 12, 2023, 08:25:58 pm »
3) Reboot twice.
I missed that part in your earlier description. That's surprising, what mechanism would be behind that? Store & retrieve works for the first reboot, and then fails the second time 'round although you have not touched the settings any further?
Offline Martin72
« Reply #110 on: November 12, 2023, 08:37:21 pm »
Can reproduce this...
Wave intensity set to 100%, transparency 50%.
After the first reboot, transparency is 70%, after the second reboot 100%...
(Kierkegaard)
Online ebastler
« Reply #111 on: November 12, 2023, 08:47:08 pm »
Ah, so the problem somehow "accumulates" and gets worse with the second reboot?
Try rebooting a third time. Maybe traces covered by the dialog window now become brighter than around it, because of 150% transparency?  ::)
Offline Martin72
« Reply #112 on: November 12, 2023, 09:52:47 pm »
It seems so and since power on is set to last state, it holds this and goes one better...
But it stops at 100%. ;D
(Kierkegaard)
« Reply #113 on: November 12, 2023, 10:24:15 pm »
Hm,
Any scope should boot at/with last settings as a default operation.
Default to factory settings should be a user only defined operation.
Default should also be definable as a user custom operation and/or all should be able to be bypassed by loading previously saved Setup file.
Offline Martin72
« Reply #114 on: November 13, 2023, 12:26:03 am »
I have to add that I consider this behavior to be a minor bug, not really decisive, just a bit annoying.
In general, my soon to follow interim conclusion about the DHO800 Scope might surprise some of you.
I've had it for almost 5 weeks now and have spent an hour or two with it almost every evening.
(Kierkegaard)
Offline Fungus
« Reply #115 on: November 13, 2023, 01:23:52 am »
That means wave intensity was 70% before you started doing anything.
No, it lags by one boot. It's not "accumulating" or doing any interpolation.
Offline Fungus
« Reply #116 on: November 13, 2023, 01:28:32 am »
Can't wait to find out what an "interim conclusion" is...  :popcorn:
(Should be in another thread though... this one is bug reports only)
« Last Edit: November 13, 2023, 10:25:37 am by Fungus »
« Reply #117 on: November 13, 2023, 04:10:49 am »
:popcorn:
I trust your impartiality and I would ask for your rating in 2 ways:
1. Suitability as a first scope. Is the UI too complex and does the OS provide suitable protection for the scope newbie managing aliasing ?
2. For the experienced DSO user.
Offline Fungus
« Reply #118 on: November 13, 2023, 02:13:38 pm »
Did I ever mention that you recognize a salesman by his selective picking of arguments and angles which suit his agenda? :horse:
He never disappoints... this new demand is brilliant!  :-DD
I typed up a long reply but I deleted it because first post says "No other discussion please".
The following users thanked this post: skench
Offline Martin72
« Reply #119 on: November 13, 2023, 11:04:19 pm »
I don't want to anticipate this because I want to post it in "my" thread, but here it is in brief:
To 1: The user interface of this rigol in particular is a bonus for beginners, you can always fall into the aliasing trap with any scope.
Regarding 2: Experienced users would not buy this scope as their main measuring device, but rather as a second one, the small form factor and the USB supply are an invitation to do so.
(Kierkegaard)
Offline Howardlong
« Reply #120 on: November 14, 2023, 12:44:02 pm »
I'm not a fan of the UI TBH: ignoring the soft buttons on the non-touch DS1000Z, there are more physical buttons & knobs on the DHO800/900 than the DS1000Z, but it's harder to use as important physical buttons are relegated to touch only, in favour of infrequently used ones, in particular the search navigation buttons. But then I'm not a fan of touch UIs on scopes anyway.
I agree with the basis of this, however with the firmware as it currently stands, it's little more than a desk ornament, particularly the 900. I do look forward to it being my field scope at some time in the future though.
Offline Fungus
« Reply #121 on: November 14, 2023, 02:29:54 pm »
I don't know of any serious bugs in the DHO800.
There's a few annoyances, that's it. All functions appear to work. It's never crashed or locked up, not once.
We'll see what the next update brings for the DHO900 but let's not pretend this is a Rigol problem. EEVBLOG has long bug threads for every new oscilloscope model from every manufacturer, including some very expensive ones.
Offline Fungus
« Reply #122 on: November 14, 2023, 02:44:11 pm »
DHO800: 24
DS1000Z: 38
Offline Howardlong
« Reply #123 on: November 14, 2023, 06:24:53 pm »
DHO800: 24
DS1000Z: 38
Why did you quote without my explicitly defined context?
What I said:
"ignoring the soft buttons on the non-touch DS1000Z, there are more physical buttons & knobs on the DHO800/900 than the DS1000Z"
MSO1074Z-S: 6 knobs, 24 buttons
DHO924S: 7 knobs, 26 buttons
The physical soft buttons can reasonably be replaced by on screen touch. That I'm not too fussed about.
My point was that there are too many regularly used primary functions that have been moved onto the touch screen, while much lesser-used functions enjoy individual buttons, most obviously the search navigation buttons.
On the same theme, the screen real estate has become unnecessarily cluttered with touch junk now, negatively impacting the waveform window size.
« Last Edit: November 14, 2023, 06:28:26 pm by Howardlong »
Online ebastler
« Reply #124 on: November 14, 2023, 06:36:16 pm »
I know I have been guilty of an off-topic post myself (which I have just deleted), in response to tautech's "final report request". But can we please relegate this discussion to a different DHO-related thread, if it needs to be continued at all?
If we want any hope of Rigol reading this thread and acting upon it, we should keep it focused on bug reports.
« Last Edit: November 14, 2023, 06:38:21 pm by ebastler »
The following users thanked this post: Fungus, UK
