Author Topic: Rigol DHO800/900 Oscilloscope Bug Reports + Firmware  (Read 277427 times)
Offline TurboTom
Re: Rigol DHO800/900 Oscilloscope Bug Reports + Firmware
« Reply #50 on: October 11, 2023, 06:35:55 am »
The built-in arbitrary waveform generator doesn't seem to contain any built-in (or pre-recorded) "standard" arbitrary waveforms. Moreover, I cannot find any method to convert a stored waveform file from the oscilloscope section (.CSV or .bin) into a waveform that would be compatible with the built-in AWG (.ARB). So apparently there's no simple way to play back a waveform that had been previously recorded with the scope. That's even possible by directly connecting one of Rigol's "Legacy" Scopes to any of their AWGs via a direct USB link!
I more and more get the impression that those folks who buy this product in two year's time will be quite happy campers...  :box:
The following users thanked this post: Jacon, Aldo22
Offline Serg65536
  • Country: ua
« Reply #51 on: October 11, 2023, 07:47:20 am »
Rigol DHO800 Aliasing effect
It's not a bug, but could be fixed. Press "Default", use 12.5 MHz (or 25, 20, 10, 5 MHz), 1k memory depth, increase the timebase until aliasing appears. Firmware version 1.00.
https://youtu.be/D_kHEUk-zKo
Offline TurboTom
« Reply #52 on: October 11, 2023, 08:15:11 am »
Please stop double posting. Thank you!
Offline Fungus
« Reply #53 on: October 13, 2023, 04:07:15 pm »
I ran several test with the threshold voltage and found that it is the threshold voltage scale issue. If I set the probe to X1 scale then everything works fine but with the X10 probe scale does not work because  the actual threshold voltage 10 times less than I set. But if I increase the threshold voltage 10 times (10V instead of 1V) then decoding starts again.
Yep. I received my 'scope today and serial decoding only works when the probes are set to 1x.
Edit: This is NOT fixed in the 1.01 firmware.
« Last Edit: October 13, 2023, 10:10:55 pm by Fungus »
Offline Fungus
« Reply #54 on: October 13, 2023, 05:32:56 pm »
Two bugs I found in the web interface:
1) When you open the web control it gives you a 1280x800 display as if it's for the DHO1000/DHO4000. The means image is stretched and blurred.
2) The window is the wrong size for the image - it's off by a pixel and that makes the scroll bars appear. Really annoying.
Also a peeve: When you take a snapshot could it be in lossless PNG format instead of JPG to preserve detail?
« Last Edit: October 13, 2023, 05:34:41 pm by Fungus »
The following users thanked this post: Serg65536
Offline Fungus
« Reply #55 on: October 13, 2023, 05:37:48 pm »
Can this be a "suggestions for Rigol" thread as well?
Offline Serg65536
  • Country: ua
« Reply #56 on: October 13, 2023, 05:59:52 pm »
Rigol DHO800 waveform update freezing bug
This bug occurs at a horizontal scale of 200 ms per division and above, when you set the trigger position to the time before the capture starts.
Setting the trigger some time before the capture is used widely to debug large signal sequences. By moving the trigger position, you can study the whole signal in small portions.
https://youtu.be/FyM5jibkgfE
Offline TimFox
« Reply #57 on: October 13, 2023, 06:52:16 pm »
I'm sure that many operators would have a problem with the two-color button display due to vision issues:  the check mark is more obvious.
Offline UK
  • Country: ma
« Reply #58 on: October 13, 2023, 07:14:02 pm »
As an app dev in the past, I think a toggle switch more preferable at nowadays UIs, and the checkbox is already a relic.
But anyway I totally agree those OFF/ON looks so-so.
« Last Edit: October 13, 2023, 07:17:33 pm by UK »
Offline Serg65536
  • Country: ua
« Reply #59 on: October 13, 2023, 07:28:16 pm »
BTW, this style of slider looks like "slide left to enable" (the upper one) and "slide right to disable" (the lower one). This could be confusing.
The following users thanked this post: Fungus
Offline UK
  • Country: ma
« Reply #60 on: October 13, 2023, 07:37:09 pm »
FIXED
Offline Fungus
« Reply #61 on: October 13, 2023, 07:38:39 pm »
I suggest we take this discussion over here:
https://www.eevblog.com/forum/testgear/dho800dho900-suggestions-thread/msg5111694/#msg5111694
It was a bad idea to start it in the "needs fixing!" thread.
« Last Edit: October 13, 2023, 07:52:15 pm by Fungus »
Offline UK
  • Country: ma
« Reply #62 on: October 13, 2023, 07:42:41 pm »
I'd put "ON" to the left but that's just me.
As well as many others. But oh why didn’t I thank Serg65536's post?
What about this? A fine example of "when you only have a hammer"?
Nothing complicated, just need to refine the labels
Ans in that SelfCal section, the toggles also could be used without any problems.
« Last Edit: October 13, 2023, 07:49:38 pm by UK »
Offline Fungus
« Reply #63 on: October 13, 2023, 08:05:43 pm »
Answered in the other thread...
Offline TurboTom
« Reply #64 on: October 14, 2023, 12:13:19 am »
Don't know if anyone observed this yet: F/W 00.01.01.00.02 -- Channel 3 not working in horizontal roll mode!
Edit: Strange, now that I cold started the scope (and I mean really cold, after ~20hrs of pause), CH3 roll mode works again. I'll let the scope warm up and re-check, since it was pretty "steaming" hot when I observed the problem. This smell from the thing is abominating...
« Last Edit: October 14, 2023, 10:39:07 pm by TurboTom »
Offline Fungus
« Reply #65 on: October 15, 2023, 07:25:55 pm »
There's an option in Setup to make the horizontal timebase knob do a "zoom". This option isn't remembered when you power-off the 'scope.
PS: I think "Zoom" should be the default for this knob. It's what people expect and "fine" is much less useful.
People are probably going to use pinch-zoom for "fine" adjustments anyway.
« Last Edit: October 15, 2023, 07:50:32 pm by Fungus »
Offline Serg65536
  • Country: ua
« Reply #66 on: October 16, 2023, 02:40:44 pm »
1) After taping "save" at the "storage" window with *.wfm format (it's available if "memory" is selected), the file is not saved, and the scope won't run again.
2) The "overlay" option should be named "overwrite", as the industry standard suggests.
The following users thanked this post: voltsandjolts
Offline Serg65536
  • Country: ua
« Reply #67 on: October 16, 2023, 02:56:04 pm »
The operator "AX+B" should be named "kA+c", because in other operators A and B are input channels, but here A and B are constants, and X is the channel.
The following users thanked this post: voltsandjolts, Lathe26, RAPo
Offline Howardlong
« Reply #68 on: October 17, 2023, 04:00:42 pm »
DHO924S arrived yesterday.
I can't get SPI decode to work at all on digital channels. Upgraded firmware to to 00.01.01, same thing (but at least the location of the analogue probe X10 setting is far more obvious).
The decoder seems to be fixed to the analogue channels whether you try changing them to the digital channels or not.
Offline 2N3055
  • Country: hr
« Reply #69 on: October 17, 2023, 04:22:14 pm »
(Attachment Link)
Ax+B is industry standard name for that function. With uppercase A and B and lower case x
Offline Serg65536
  • Country: ua
« Reply #70 on: October 17, 2023, 06:28:07 pm »
Please, check other operators on the DHO800 (A+B, A-B, A||B, etc.): all other operators show A and B as actual captured waveforms, but in the operator "AX+B" letters A and B represent the numeric constants.
So, to prevent confusion, either the mentioned operator should be renamed, or all the other.
PS: I would prefer mathematical conventions: "x y" - for the waveforms, and "a b c" - for the constants.
Offline ptluis
  • Country: pt
« Reply #71 on: October 17, 2023, 07:18:59 pm »
Two more nice features ( |O) I've found on youtube
« Last Edit: October 17, 2023, 07:31:04 pm by ptluis »
Offline Martin72
  • Testfield Technician
(Kierkegaard)
Offline ptluis
  • Country: pt
Offline Serg65536
  • Country: ua
« Reply #74 on: October 17, 2023, 07:43:23 pm »
That's normal behavior for all oscilloscopes. It's due to the input amp overload. You need to remove input circuitry overload, to see the undistorted signal.
