Author Topic: RIGOL DHO802 & DHO812: sample rate & external trigger  (Read 709 times)
Offline Yuriy V.Topic starter
  • Country: ru
    • trengtor custom
« on: August 15, 2024, 04:48:47 pm »
I ask owners of DHO802 & DHO812 models to answer the following question. Does the maximum sample rate of the channel(s) drop when external sync mode (Ext Trig) is enabled?
I didn't find an answer in the documentation. I also couldn't find it on internet sources.
« Last Edit: August 17, 2024, 06:13:17 pm by Yuriy V. »
Online egonotto
Re: RIGOL DHO 802/812: sample rate & external trigger
« Reply #1 on: August 15, 2024, 08:13:36 pm »
Hello,
in the data sheet, the external trigger is only specified in edge mode. This indicates that the sample rate is not changed.
However, I do not have a device to check this.
Best regards
egonotto
The following users thanked this post: Fungus, Yuriy V.
  • Country: ru
    • trengtor custom
Re: RIGOL DHO802 & DHO812: sample rate & external trigger
« Reply #2 on: August 16, 2024, 05:43:54 pm »
Still waiting replyes from DHO802 & DHO812 owners
« Last Edit: August 17, 2024, 06:13:49 pm by Yuriy V. »
Online Fungus
« Reply #3 on: August 19, 2024, 03:24:48 pm »
Maybe there aren't any. Everybody buys the 4 channel models.
  • Country: ru
    • trengtor custom
« Reply #4 on: August 19, 2024, 05:42:13 pm »
I'll wait. I don't believe there's no one with 2-channel  ;)
« Last Edit: August 19, 2024, 08:32:08 pm by Yuriy V. »
Offline Elextro
« Reply #5 on: August 22, 2024, 10:16:23 am »
Hello, I have a DHO802, I bought it because I am not going to use the 4 channels and because it also saved me some money. If I set the oscilloscope to the 1khz test signal and activate the maximum memory depth of 25Mpts, the oscilloscope sets itself at 1.25 Gsa/s. In the trigger menu I activate the external synchronization input and I do not observe any variation of the 1.25Gsa/s. Of course, if I also activate channel 2 the sampling frequency does drop by half, to 625Msa/s and memory depth at 10Mpts. But it does this regardless of whether the external trigger is activated or not. My conclusion is that activating the trigger does not influence the maximum sampling frequency, only activating the two channels divides that factor in half. I hope I have helped you. Greetings
« Last Edit: August 22, 2024, 10:33:49 am by Elextro »
The following users thanked this post: egonotto, thm_w, Fungus, Yuriy V., csuhi17
Online Fungus
« Reply #6 on: August 22, 2024, 01:23:33 pm »
Hello, I have a DHO802, I bought it because I am not going to use the 4 channels and because it also saved me some money. If I set the oscilloscope to the 1khz test signal and activate the maximum memory depth of 25Mpts...
I think you should be able to get 50Mpts by generating a license key.  :)
Offline Elextro
« Reply #7 on: August 22, 2024, 03:34:34 pm »
At the moment I manage well with 25Mpts. I don't want to lose the warranty...but in the future I will surely expand to 100Mhz and 50Mpts as you suggest. By the way, is there anything new to generate the license key? Thank you
« Last Edit: August 22, 2024, 03:37:14 pm by Elextro »
