Author Topic: SDS 1202X-E Auto Power Up  (Read 706 times)
Offline MitiTopic starter
« on: September 22, 2023, 04:04:23 pm »
We’re using an SDS 1202X-E in an automated test system and I wonder if there is a way to make it power up in full power after a power loss. It is inside a rack and it would simplify operator’s life if he didn’t have to push the power button.
Cheers,
Miti
Fear does not stop death, it stops life.
Re: SDS 1202X-E Auto Power Up
« Reply #2 on: September 22, 2023, 07:16:28 pm »
I was thinking more like an option in one of the menus. Like a PC has options in the bios to recover from a power loss in the last state, standby or on.
« Reply #3 on: September 22, 2023, 10:52:56 pm »
Unfortunately not for these 2ch X-E models, not even with the latest V1.3.27 firmware.  :(
However 4ch X-E do have this feature as do many other models from Siglent.
I'll lodge a feature request.
The following users thanked this post: Miti
« Reply #4 on: September 23, 2023, 01:43:12 am »
Thanks tautech,
Another plus for Rigol, hard power button.
« Reply #5 on: September 23, 2023, 03:37:45 am »
Thanks tautech,
Each to their own and you might want to check out the Repair board for current threads where mechanical power buttons have failed.....certainly replaced a few in PC's I have had.
It seems the similarly priced SDS1104X-U has a POL feature, well according to the manual it has but I need get one out to confirm. Gimme a bit.
« Reply #6 on: September 23, 2023, 04:51:04 am »
Confirmed, 4ch X-E and X-U have the POL feature.
