Just thought I'd give a thumbs up for this brand new product from Rigol.
The DG5102 is a dual channel waveform generator. 100MHz output, 1GSa/s.
My use was to create a doppler tone for testing a weather radar's doppler signal processing.
I need 1 channel to simulate the transmitter's burst, triggered from the signal processor.
The second to simulate a varying receive frequency about the nominal IF of the receiver.
The Rigol does it with ease. I can create a burst signal on channel 1, and use frequency sweep on channel 2.
The frequency sweep can be specified as the centre frequency and span - perfect for my needs.
Even better if you set the output impedance to 50ohm, you can set level in dBm (which was not possible with my old test system).
That however is a pretty simple usage.
We had the unit demonstrated a few months ago by a rep from Rigol themselves whilst the unit was still in the development stage (SW version of my unit is 00.01.01
) and he demo'd capturing a waveform from a DSO, storing it in the DG5102 and replaying it adnauseum. I believe you can even sequence the replay via an external trigger - perfect for radar testing.
It isn't cheap @ ~$4000 AUD, but since it is not a personal purchase that is not so much of a concern.
The best part for myself is I can finally dump the pair of sig gens cross coupled with the 10MHz references and assorted other "bits" I had been using and replace them with a unit that is a fraction of the size of either unit, that could quite well be easily rack mounted if need be.
The only disappointment so far is the web based control of the functions is not working, but given a SW version of 00.01.01 I'm certain there is scope for improvement on that front
http://www.rigol.com/templates/T_Product_en/index.aspx?nodeid=1095
