Very impressive build quality.
The resistors will connect to testpads on the bottom so the ATE can read the setting throught the bed of nails contactor.
Early in the video you had the heatsink off one of the output amplifiers. looks like twin SO8 chips with a silver reverse ink printing on them. what are those ? look like AD or TI parts ... later in the video the heatsink was back on.
I had an interesting chat with the rigol people yesterday. we spent about 4 hours going over what i am looking for in a product and they were very carefully taking notes of all the remarks i had to make.
i am looking at a different line of ARB's , the DG5000 series , because they also have a didigtal interface in the back ( you have access to the digital stream going into the DAC as well as advanced pettern generation capabilites like I2C , SPI and others.
Rigol is really serious about their new products. The evolution of the company is that it started about 14 years ago by 3 university students that made little handheld or bare board products . simply because real equipment as too expensive.
Gradually they got better , partnered with some 'big boy' as OEM , and gained a bunch of know-how.
They improved their production and design capability greatly , launched a few other products , partnered up again as OEM but have a full blown desing team. there's about 400 people at Rigol with over 150 design engineers ... They are serious and in it for the long run.
A couple of years ago they scooped up a bunch of engineers from two companies that now sail under the danaher flag ... and those guys brought some 'big guns technology' to the company...
I had a bunch of really oddball questions and their field-apps engineer is going to check out what can be done. The guy was very knowledgable on how the machine works internally . I had questions on their multimeter . Very specific details like the autozeroing sequence , being able to disable it , read the residual etc ... all possible. He knew exactly what i was talking about ( he was one of the 'danaher escappees and very familiar with a range of popular 6-1/2 and 8-1/2 digit benchtop meters.... the rigol machine can do the same things as that one .. )
Same for the scope. A lot of scopes have problems dealing with the following :
you have a 100mVpp signal superimposed on a 10 volts DC signal. Show me the 100mVpp signal , using DC mode , with the highest possible number of divisions on the screen.
There are two scenarios :
- a scope where the offset is injected BEFORE the gain stage. in this case the input preamp is a summing amplifier , you subtract the DC before sending the residual through the attenuator / gainstage and digitize it. Scopes employing this architecture have no problem showing a 5 division high signal ( 20mV div setting ) on the display.
- a scope where offset is injected post attenuation... these cannot show you the signal. they do not have enough range an d you can either see a liitle bit of wiggly , or have the signal clipped.
the first solution requires a very high precision DAC and a good summing amplifier.. costly stuff.
the second stuff is done in software ....
Now, suerely theres' people out there thhat will say : switch the scope in AC mode..
but , that's not doable in all cases. when looking at the switching node of a step-down converter you may want to investigate things like shoot-through , or misfires of a synchronous resctifier... you need to be able to find out what is both the DC level of the signal , and have a realy good view of whatever ringing or other small signal there is superimposed.
So you need a high dynamic range.. only scopes that emply the summing amp pre-attenuator can do this...
