Hmm, I don't have my 1074Z-s anymore or I'd do some testing myself. It looks like it doesn't want to offset by the voltage you want. It may still work for your needs but you'd need to watch out for common grounds. If your device is floating you'd be ok, but then if you were to probe it with the scope etc you'd be back to the same problem of DC offset.
