Hello,
I have a problem after to have updated my old DG1022 :
Before I had : 00.03.00.08.00.02.08
I updated it using
https://beyondmeasure.rigoltech.com/acton/ct/1579/p-00ac/Bct/-/-/ct36_0/1?sid=TV2%3AQ2jKaGpUj (03.00.00.01).
Firstly I upgraded to bootloader 03 (from folder DG1022X(DSP)Update(Bootloader)_03 )
Then I updated firmware (from folder DG1022X(DSP)Update(Normal)_00.03.00.00.01)
At startup, I see the following version number : 03.03.00.08.00.03.00
So the upgraded seems to have succeed.
The instrument starts well and displays the user interface, but some of the buttons (numeric keypad, last button on top of CH1/CH2...) are not usable anymore.
When I press any, the device shows the following message : "the key has been locked. Use please unlock".
Any suggestion to fix this ? Thanks a lot.
