Author Topic: Rigol DG1022 Firmware help please!  (Read 3773 times)
Offline gm0otbTopic starter
« on: October 26, 2015, 08:05:57 pm »
I recently updated my firmware on the DG1022 as per instructions in other forum topic, It now reads "00.03.00.08.00.02.10" and my Numerical keypad, left/right buttons and the last two blue soft keys all ask to be unlocked. I also can not access the DG1022 via SPCI or Ultrawave to unlock keys that way.
If someone has the original loader and/or  firmware file or has the correct SCPI command to try in the USB port it would be greatly appreciated.
I have requested firmware from Rigol, but not holding my breath.
Thanks.
Ray.
Offline JimBeam
Re: Rigol DG1022 Firmware help please!
« Reply #1 on: December 06, 2015, 03:36:55 pm »
I had the same problem >:( and after reading your message, I had the idea to take a look inside the DG10x2Update.GEL file, perhaps I could find something interesting there, and while doing so, I stumbled upon the string "KLOC" rsp. "KLOCK" - mmhh, I thought, could mean KEY LOCK - and as this string was in the neighborhood of a few other SCPI commands, I just assumed it also being a SCPI command.
So I fired up the UltraSigma Software, right-clicked my device and selected the "SCPI panel control". Entering "SYST:KLOC?" gave me a "0000000000000000111111111111111100000". Ahh, this looks promising! There are 16 bits being at 1 - exactly the number of keys that are locked ;)
So I quickly entered "SYST:KLOC 0" and a "SYST_KLOC?" again, and BINGO - all zeroes now!
Power-cycling the DG1022 and while keeping my fingers crossed, I pressed the '7' key (which was one of the keys that didn't work before), and YEAH  :-+ that was it!
After doing a pro-forma Utility -> System -> Setting -> Default, I now have an operational DG1022. Easy as 123 - if you know what to do :-DD
OH, btw. my version now reads as 03.03.00.08.00.03.00. Does anybody know, what the first 03 means?
AFAIK the first two numbers are the bootloader 03.03 (which everywhere I read, is 00.0x !), the next 2 numbers are the DSP version 00.08 and the rest is the firmware version (0.3.0)
« Last Edit: December 06, 2015, 03:43:11 pm by JimBeam »
The following users thanked this post: mcinque
Offline mcinque
  • I know that I know nothing
« Reply #2 on: December 06, 2015, 07:37:33 pm »
+1 JimBeam!  :-+
The following users thanked this post: orbiter
Offline mgc997
« Reply #3 on: February 03, 2020, 06:22:26 pm »
FYI, I was unable to connect to my DG1022 using Ultra Sigma to send the SCPI commands. After hours of trial and error I was able to access the DG1022 by using Ni Max Version 5.5.0f0. Under "Devices and Interfaces" I selected the DG1000 Series usb connection. I then selected "Open VISA Test Panel" then under "Input/Output" panel "Basic I/O" under "Select or Enter Command" I cleared the data in the window and typed in: "SYST:KLOC 0" and selected "Write" then "SYST_KLOC?" "Read" it confirmed that now all "zeros" keys are now unlocked.
Hope this helps those who couldn't clear the locked keys after firmware update
