Author Topic: Rigol 1054Z to 100mhz help  (Read 2903 times)
Offline GazmonTopic starter
« on: March 05, 2019, 10:03:21 pm »
Hi all
Recieved this scope yesterday and it came with all options unlocked firmware 04.04 installed  , could anyone tell me what I need to do to get the 100mhz unlocked as well please
Appreciate there’s lots of info about it , just looking for clarification and little help
Thanks
Gazmon
« Last Edit: March 05, 2019, 10:05:52 pm by Gazmon »
Offline alsetalokin4017
Re: Rigol 1054Z to 100mhz help
« Reply #1 on: March 05, 2019, 10:16:19 pm »
How many times have you tried already? Are you locked out yet?
It's sort of a rite of passage. Step by step instructions have already been posted many times, questions asked and answered many times. Sometimes people even share their serial numbers and get someone else to generate the key code on a locally run keygen instead of using the one on the web.
So... do you know the secret handshake?   :-DD
« Reply #2 on: March 05, 2019, 10:18:31 pm »
Just kidding. You will get all the help you need.
The first thing to do is to check your serial number, both on the label on the back of the unit and in the complete System Info screen. I like to put the serial number into a text file on my computer, so that later on I can just copy-paste it somewhere useful... like into the keygen.
« Reply #3 on: March 05, 2019, 10:19:27 pm »
I’ve not tried anything yet
« Reply #4 on: March 05, 2019, 10:21:05 pm »
Ok can get that , what’s next the please
Sorry for being asking questions that probly been answered many times
Online Fungus
« Reply #5 on: March 06, 2019, 05:16:23 am »
What info have you seen so far?
Offline ercapoccia
« Reply #6 on: March 06, 2019, 07:58:44 am »
If you use google this is pretty much the first results
https://www.eevblog.com/forum/testgear/is-rigol-ds1054z-still-hackable/
« Reply #7 on: March 06, 2019, 08:32:25 am »
Ok cheers will look at this today
Just one thing as my unit has already got all the official options from new can I just select the 100mhz option only or will this effect the rest
Is it better to go for the DSER option regardless ?
Offline JohnPen
« Reply #8 on: March 06, 2019, 09:23:57 am »
DSER covers all you need.
Online Fungus
« Reply #9 on: March 06, 2019, 03:05:42 pm »
It makes no difference. DSER enables everything.
« Reply #10 on: March 06, 2019, 03:42:36 pm »
Just done the upgrade all is looking good thanks
One thing I would like to ask is how do I get to view the intensity grading feature?
Just getting to grips with this scope, so apologies
Online Fungus
« Reply #11 on: March 06, 2019, 03:59:04 pm »
Turn the knob labelled "intensity". You can also do it via the "display" menu. Section 12 of the manual has full details.
https://youtu.be/ETCOhzU1O5A?t=398
« Last Edit: March 06, 2019, 04:04:41 pm by Fungus »
« Reply #12 on: March 06, 2019, 04:05:00 pm »
Hmm that doesn’t seem to give me the same results as the video?
No gradient just brighter lines
Online Fungus
« Reply #13 on: March 06, 2019, 04:05:49 pm »
You probably don't have a varying/modulated input signal like Dave does.
The following users thanked this post: Gazmon
Offline metrologist
« Reply #14 on: March 06, 2019, 04:08:30 pm »
The intensity grading is a viewable feature. The signal trace displays brighter in areas where the signal appears more often, so you need to be viewing a dynamic signal such as the envelope of an AM signal. You won't see it on a sine wave, for example.
Intensity grading is not the intensity knob.
« Reply #15 on: March 06, 2019, 04:11:52 pm »
Guessing thats why , im just hooked up to my signal gen, viewing a sine wave
« Last Edit: March 06, 2019, 04:13:31 pm by Gazmon »
Online Fungus
« Reply #16 on: March 06, 2019, 04:17:09 pm »
Does your signal generator have AM?
« Reply #17 on: March 06, 2019, 04:38:39 pm »
well its just a cheap feeltech fy3200, I don't think it has AM , but correct me if im wrong
thanks for the replys
