It seems some Siglent scopes FW update will wipe out old self-cal data, you can see the base line drift a lot from 0V after update.
The factory calibration data is not affected by FW update, no worries after self-cal.
I sometimes see a popup menu advice me to do a self-cal after update has completed, but most time not. Just hope they give enough information in the FW release notes.
