I have a 1052E that's been hacked to 100mhz. I have an old piece of equipment that outputs an X, Y and Z "vector" signal onto a display tube. Hooking up the Rigol in place of the tube, I can see the picture but it's small in the lower right corner of the screen. Adjusting scale full on X and Y increases it's size slightly, but still the image is barely taking up any of the screen. Am I missing something? I've had no issue filling the entire display area using an old HP analog scope.
Are you sure the signals don't have a DC offset?
Maybe put a capacitor in series with each signal and use AC coupling? I'm not sure about the Z input and whether it should be capacitively coupled.
I figured out the issue. I was misunderstanding the controls. They don't work quite the same way as my older analog.
Question. Is there a z-input (intensity) on the 1052? It would also be nice if there was a persistence option in-between none and infinite (but realize that would be tricky to implement and somewhat comes for free on analog scopes).
Having a Z-input is pretty rare for digital scopes. I know there are a couple out there but don't remember specifically what models they are.
Correct, and to directly answer the specific question asked, no, the Rigol 1052E definitely does not have a Z input.
Yes I concluded this was the case. Anyone know which digital scopes have a Z-axis input? I've read that some higher ends scopes also have configurable "digital persistence".
