Author Topic: Agilent/HP 8664A  (Read 2433 times)
Offline tchiwamTopic starter
Agilent/HP 8664A
« on: January 02, 2021, 09:55:51 pm »
Hello,
  for those who are having an error 5030,xxx I rewrote the code in python, the code is from the Service manual. I will post it after a clean up to git something.
If anyone is having this document somewhere, it would help 08645-90024. I am dumping all the mux Voltages too, and right now some of the DIAG GPIB code is a bit unknown...
I managed to get the great +0 result after special function 320 !!!  Happy camper.  8664A Option 004 008, soon to be 8665B when I get the roms
Happy new year.
Offline rickells
Re: Agilent/HP 8664A
« Reply #1 on: January 07, 2021, 05:03:24 am »
hi,
Did you post the Python code & procedures for your HP 8664a ?
  If so, can you post the web link for download ?
I would like to try to use them for the HP 8665b 6GHz Signal Generator.
I  recently purchased  a HP8665b with ROM version 4.2.2
  I am not familiar with it, yet.
It has some issues, and I am trying to determine what is wrong with it.
1) The Right-side VFD display does not light up, so I can't set nor read Amplitude values.
2) as a result of the bad display, I can't tell if there is an Rf O/P or not.
3) After power On, a self-calibration starts up on the Left-hand display.
After several long minutes the display states: "Result  8,043,311" and
   then displays: "hardware failure" .
after a few moments displays "1.5 GHz".
I can change the frequency, using the front panel controls.
I have gotten the cover off ( single piece steel case; ~ 30 Torx screws ).
that is as far as I have gotten today.
4) I will be measuring PS voltage values soon.
I just found a .pdf  service manual online tonight with some PS circuit diagrams, mechanical
& some diagnostic, but no Assembly (module) circuit diagrams.
For HP
    https://literature.cdn.keysight.com/litweb/pdf/08645-90145.pdf?id=88786
I don't see any reference to a battery inside the instrument.
Is there one ?
I'd appreciate any insight you have if we can discuss as I go along ?
Do you have any schematics as .pdf's that you can share ??
thank you,
r
« Reply #2 on: January 07, 2021, 03:57:18 pm »
Hello,
8,043,xxx without a plus or minus can be a blessing or a pain.
Before opening the case:
- Let it warm up 30minutes
- Check if you have a 10MHz behind the unit, if you do it may just be a recal
- Run the MW Loop adjustment and check the values (without playing with the pots)
- Try the 171, might not work without the dip switch set
Open the case
- Flip the switch 1 , closest to the back of the 4, to allow you to run the IDL
- Lift the A14 15 16 slot cover
- Measure the power supply at the I/O board, back right partly hidden under the 40 pin flat ribbon, I bet those are OK since you got the 8,043,xxx
- MW Loop adjustment, do it again
- HF Drvr adjustment
- Check all of the smb sma connectors for loose ones
- 171 recal Go back to MW Loop a couple of times
- Clear all messages
- Clear all memory
Special 320 and take all failures one module at the time
I have a Check module in my repo, at the end of the service manual you should have most of the values for each MUX, check agains't them if you still have a fail somewhere, post it here and let's sort it out. Not all modules are there but I can make / add modules if you find failures elsewhere.
Get the +0, close it all up, re test and it should be good. Redo all tests and check the MW Loop values
The only thing missing for my 8665A to be a 8665B to work is a set of ROM... Looking for a "cheap" unit on ebay...
This is my repo of GPIB bits , you may need gpibeth.py in your path to import it
https://github.com/tchiwam/GPIB
« Reply #3 on: January 07, 2021, 04:09:16 pm »
One of the document that would help a lot is 08645-90024 I think it would help a lot the 86xxx series signal generator owners...
Offline rickells
« Reply #4 on: January 07, 2021, 05:15:03 pm »
hi tchiwam,
I tried the URL that you provided:
I also tried:
https://github.com/tchiwam/gpibeth.py/GPIB
https://github.com/tchiwam/GPIB/gpibeth.py
but all failed to locate your web site !!
- I do not understand what you meant by:
" This is my repo of GPIB bits , you may need This is my repo of GPIB bits , you may need gpibeth.py in your path to import it
https://github.com/tchiwam/GPIB in your path to import it "  ??
Can you provide the correct path so that I can get the Python GPIB code ?
thank you,
Offline rickells
« Reply #5 on: January 07, 2021, 05:17:06 pm »
Offline rickells
« Reply #6 on: January 07, 2021, 05:49:14 pm »
Can't find the 90024 MAN.
sigh.
From the Keysight website,  can get:
Operation and Calibration Manual HP Part 08645-90023.
I see other, non obtainable manuals:
Service Diagnostics Manual HP Part 08645-90104
Microfiche Operation and Calibration Manual HP Part 08645-90026
Microfiche Service Diagnostics Manual HP Part 08645-90028
Let me know if you get .pdf's
thank you
