Author Topic: RF Explorer Signal Generator  (Read 11226 times)
Offline Terabyte2007Topic starter
  • It is purpose that created us... That defines us..
« on: November 22, 2014, 10:52:00 pm »
Just picked up the new RF Explorer Signal Generator. This is a small handheld RF frequency generator capable of 24MHz to 6GHz with a .5ppm frequency stability! It is temperature compensated 0-45C with both frequency and amplitude sweep functions and a 1Khz step resolution. The firmware and software are still in late beta but seem to work well. So far the testing I have done is impressive for the $200 price tag. If you couple this with the RF Explorer spectrum analyzer using the latest build of the software you can get a nice tracking generator setup which seems to work very well.
I had already purchased the RF Explorer Spectrum Analyzer prior to this which makes this RF Generator a very nice companion to the SA. I have provided links to the Arocholl website and also seeed. Even though seeed is out of stock Amazon has quite a few.
http://micro.arocholl.com/index.php?option=com_content&view=article&id=124:rf-explorer-signal-generator&catid=40:article
http://www.seeedstudio.com/depot/RF-Explorer-Signal-Generator-RFE6GEN-p-2074.html
Eric Haney, MCSE, EE, DMC-D
Electronics Designer, Prototype Builder
Offline Marco
Re: RF Explorer Signal Generator
« Reply #1 on: November 22, 2014, 11:08:57 pm »
So is this a sine wave or a square(-ish) wave generator?
Online Fraser
« Reply #2 on: November 23, 2014, 12:44:24 am »
I also own one of these
 A very handy tool especially as I aready have the Explorer. Not a replacement for a bench RF sig gen though.
« Reply #3 on: November 23, 2014, 02:37:30 am »
This was snapped at about 43MHz. I will check the higher frequencies tomorrow. It's square(-ish), at least at the lower frequencies.
Online nctnico
« Reply #4 on: November 23, 2014, 11:41:03 am »
It will output a square wave in the GHz region as well.
« Reply #5 on: November 23, 2014, 01:51:23 pm »
Absolutely. I have a decent Rigol bench SA which can run circles around this RF Explorer, but for a small quick portable signal source it's well worth the money. I used it to check the carrier on a few radio's the other night, connected my 50 Ohm antenna and worked like a champ!
« Reply #6 on: November 23, 2014, 01:52:56 pm »
Thanks, the wife was yelling at to last night to hurry up so I only had time to check and grab the lower end of the range.  ;D
Online nctnico
« Reply #7 on: November 23, 2014, 02:47:02 pm »
Please don't connect the RF explorer to an antenna! You'll most likely cause interference in many frequency bands!
« Reply #8 on: November 23, 2014, 02:52:36 pm »
These were quick isolated tests. Please explain, the spectrum on both my Rigol and PC based SA did not show any other spurious frequencies outside the selected generated frequency. I would be interested to know more about your post.
Online nctnico
« Reply #9 on: November 23, 2014, 03:00:23 pm »
The RF explorer is based on the ADF4351 chip. I have experimented with the ADF4351 a lot; because the ADF4351 outputs a square-ish wave it has a lot of energy in the harmonics starting from the second harmonic. If you output a 90MHz signal it will also have a considerable amount of energy at 180MHz, 270MHz, 360MHz, etc. This should be visible on the spectrum analyser.
« Reply #10 on: November 23, 2014, 03:05:43 pm »
Ok, now that makes sense. Thanks for the input. I have had very little time to play with this unit so far. Thanks again!
Offline Marco
« Reply #11 on: November 24, 2014, 04:30:22 pm »
The higher harmonics don't really matter for a tracking generator I guess.
Offline Mr Simpleton
  • Not the sharpest knife in the drawer
« Reply #12 on: November 25, 2014, 11:09:43 pm »
I have yet to do a teardown of a RF Explorer sig gen but looking at the specs, I highly doubt you will find an Analog ADF chip there!
It's much more likely to be a Maxim 2870 (or 2871) which seems to match the numbers dead on!
Not that it makes a big difference they both do offer good performance on lower frequencies  but pretty poor above 1 GHZ, and the square-ish wave output.
Still, nice implementation and I can see with some simple add-ons this may be a useful little gadget!
Offline SNGLinks
« Reply #13 on: December 02, 2014, 03:13:06 pm »
Here are pics of 3 of the chips in my RFExplorer Sig Gen.
Ashley
