I have a Multicomp MP710259 (which I assume is equivalent to the KEL103 and the Tenma 72-13210). The software supplied on CD ROM was version 4.1 and is useable now, but it took some experimenting. I am using the supplied USB cable. One help is to open the folder found in Program Files (x86) and change the permissions by right clicking the Configuration settings files, select Properties, then Security, then Users, then Edit, then Users and finally Allow so those files can be written to by the program.
When using the graphs, you can click on the min and max values and change the scales. Also, you can right-click a chart and then clear it.
I hope some others discover more about this software as it seems at least somewhat useful. Thus far, I am liking this electronic load a lot!
