just a silly question - what is adjustment resolution in CR mode? I can't find it reviewed in any video. It is very useful in testing limit of SMPS.
Hi. It's been some long time, but I saw your question only now.
I have KEL102, and the adjustment resolution in CR depends on the range:
- 0 - 9.9999 R the resolution is 0.0001 R
- 10 - 99.999R it is 0.001 R
- 1000 - 9999.9R it is 0.1 R
Maximum is 7500 R. Minimum is 0.05 R.
0.0001 R is crazy resolution. I tried to confirm it really works, using Keysight 34461A and Li-Ion battery (the most stable voltage supply I have right now), but the lowest I saw the difference was 0.01 R. Everything below 1 mA was noise. Perhaps with better setup it could be measured.
