Yes, you did not buy from factory, you buy from reseller who have select this model from factory.
No, I don't think that's correct. I think Owon has changed their policy. The reseller I bought it from has been in contact with Owon about these models since middle of May. Here are some excerpts from their communication with Owon (roughly translated to English):
19 May 2011: Bad news! Just now the entire stock of Owon PDS7102T was bought by another company, and as they had already indicated, OP = OP. Our expectation was that they would not go so fast... So the PDS7102T is already sold out, a shame, because this was the most popular model in this action. In consultation with Owon, the SDS7102, brand new (faster, more memory, LAN/USB2.0/VGA), has been added for an additional cost of only € 35."
24 May 2011: Today I learned from Owon that the SDS7102 has no LAN port. Furthermore, they did not expect that we would suddenly want around 40; they can produce 20 in early June, but it is not known when the rest will be ready. I am awaiting the response of the production department."
So, in these communiques from Owon, VGA does NOT sound optional. If what you say is true now, then maybe Owon have changed their policy since then to make/save some extra money (which would explain all of the data floating around the Internet which does NOT list it as an option).
Here is original promotional brochure for SDS line:
http://www.eleshop.nl/downloads/Owon/SDS.pdfThis is from an early spec sheet for SDS6062, where it lists USB
or RS-232 as the communication port:
"Communication port: USB2.0 or RS-232,USB flash disk storage"
