Not sure if anyone's encountered this problem before, I looked for a bit through this thread, but couldn't find it. Sorry if it's already been mentioned.
I have noise on channel 1 that reads about +60-100mV on 5V/div.
The noise is proportional to the V/div (e.g. 1V/div gives 12-20mV of noise), and it wanders constantly between two values, which suggests two things:
- the noise is just before the ADC, and after input scaling circuitry
- the noise is not only AC, but it contains a DC offset, suggesting that something in the scaling circuitry output or ADC input is poorly tuned, and some other AC noise exists that is causing the wandering
If anyone has any pointers, it'd be very much appreciated.
EDIT: forgot to mention, I've tried self-calibrating, rebooting, using a different probe (with GND clip connected to probe tip), removed the probe, tried compensating the probe. Even measuring the 5V square wave test signal gives me the same noise on channel 1.
Cheers,
David.
