So much about Owon noise, nearly like it is only Owon special problem and all others do not have.
Here looked Owon, Siglent and Hantek. With as same settings as can. All tests probe comp is adjusted for scope and in all tests exactly same probe.
Vertical 50mV/div with probe setting 10x in scope and in probe. (real scope input is of course then 5mVdiv) Coupling DC.
Horizontal 500us exept Hnatek 400us / div.
Normal sampling, and memory 1M Owon, 2M siglent, 1M Hantek.
Display persistence 5s.
All scopes first image input open, next probe in input but shorted as in pictutre. Then Probe connected to Comp Out GND as see in image. Last probe connected normally to Probe Comp output.
Environment: all switch mode supplies shutted off, computrers off. Only this scope connected to mains what is under test. Even Lights are linear DC supply powerered LED. Not strong TV, FM or AM stations nearby. Also building WLAN shutted off.
Owon, Siglent and Hantek all are 100MHz models without modifications.
Just for fun and for realize what is what in this heavy talk about just Owon noise.
