Brüel & Kjær was in their old days known for well engineered test gear for acoustics and vibration measurements. Over the years, they have developed quite a few bits of kit within the field, and in the end of the 80s a little handful of these were computerized. In the midst of this, the 2318 graphics (thermal) printer was made, most commonly seen with a serial interface module for adding on-the-fly portable printing to this handful of their computerized test devices.
It can be mentioned, it's not all proprietary. Even the plug is not your standard RS-232, the signal-levels are and the manual does tell how you can make a cable for hooking it up to regular RS-232. It also gives you a rundown of the command set you can use to do stuff like printing bar-graphs and the likes, including changing the character-set. The list of 11 built-in sets mentioned is pretty standard, from ASCII to various European localizations, Greek, Cyrillic, even Katakana.
Yesterday, I decided to back up the ROM from my particular printer (I tend to do this with most of my lab gear just in case of future bit-rot), and had a brief look. Turns out my unit has an additional character set not mentioned anywhere else...
...Runes.
Yes, runes. The old runes used in Scandinavia up until the middle-ages or so. It even seems like there has been an attempt at covering both upper and lower case for some of these, and I have to say.. When it comes to B&K I usually expect a lot, but this was far beyond what I could imagine! Unfortunately I don't know which command I need to use to select this, and disassembling the code is panful to say the least due to a lack of good disassemblers for the RCA 1805 (and other COSMAC series CPUs).
(For reference, the version of the Firmware ROM is VP1915, other versions may differ.)
