some update. I received my pcb order to have the connector available outside to play with this saturday.
I just tried to use the serial port of my TDS3000(A) but with no success.
Seem like the A model, we must use the hardware RTS/CTS control flow (don't have anything to test against for the moment) or the serial port is disabled by default (fuxxored).
I would more easyli go for the second idea as there is nothing about a serial port in the menus (my 3032C has serial port config event without an extension card).
So getting a Floppy emulator to downgrade the firmware seem now less urgent
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
BTW for the screen as it's connected "directly" to the lcd connector the signal is present as soon as the scope is on.
pin 2, 11: DotClock 25MHz
pin 3 : HSync 31.5Khz (lonw 31,72us)
pin 4 : VSync 60,16Khz (low 16,62ms)
Pin 6-9 : Red [0-3]
Pin 51,52,54,55 : Green [0-3]
Pin 56,57,59,60 : Blue [0-3]
I have mapped the datalines and some of the address lines too but for the moment i can't confirm their axact assignation(just some guess).
After some more playing i think like james_s that some pins are used to detect the type of extension card. But it seem more tricky than some lines to ground.
I have a bunch of pins that have no signal on them :
High state : 13, 15, 24, 65, 66
Low state : 14, 16, 18, 19, 20, 22, 23, 25, 61, 62, 63, 64
Given the position of the pins i suspect the LC00A and LC08A to have something to to with the identification of the module.
They're probably only for the logic to enable/disable the 245's of the GPIB controller, but it can be a possibility that one of thoses is used to act as a "ROM" on the data bus for a byte to identify the module.
Edited to add pins 61 to 64.
