Author Topic: Request for DSO8060 RS232 serial lead pin out  (Read 1012 times)
Offline pete.cross@ihug.co.nzTopic starter
« on: October 17, 2015, 10:55:34 pm »
I request the correct pin out for the RS232 serial lead that connects the Hantek DSO8060 handheld scope to a PC serial port, please.
I received a DSO8060 Hantek handheld scope, with a DB9 female to RJ45 lead with the following connections.
DB9 female      pin RJ45 pin
1                        No connection
  2                         7
  3                         4
  4                         8
5                         No connection
6                         No connection
  7                         5
8                         No connection
9                         ?No connection
This cannot be correct, because pin 5 on the DB9 is used for signal ground. If this is not connected, then it will not work. Can you please reply with the correct pin out for this lead?
Thank you for your efforts in this.
I will send you a chocolate fish if your post gets it working !!
(Offer valid till 25 Oct 2015).... O0
« Last Edit: October 20, 2015, 05:46:00 am by pete.cross@ihug.co.nz »
