Having successfully fixed my U1253B OLED display, which went dim a few weeks ago, i thought i´d share my experience as well:
First, I thought wtf, googled, and found out about the OLED-problem. I decided to send the meter to the vendor, maybe there was some kind of warranty or good will, and got a service offer (see below). Interesting business model.
As i didnt´t want to spend hours making pcbs and stuff, i followed the procedure from kostelectronics switzerland:
This is the replacement display at taobao in chinese, it´s offered for U1273 and U1253:
https://item.taobao.com/item.htm?spm=a230r.1.14.101.7c43260eXXQFvS&id=591402268582&ns=1&abbucket=19#detailLuckily there is an english taoabo site, tbfocus.com, and this is the display there:
https://shop.tbfocus.com/item.php?id=591402268582#4133487996875I ordered the display via a tabao sales agent and received the diplay about 10 days later. It was a straight swap, just cut 7 pins which were protruding from the left side of the display pcb.
The display lower end is a bit longer, I therefor put countersunk M2 screws, which fit underneath the protruding display glass plate. Also I put insulation on und under the pcb where the two upper srews are because there are pcb tracks very close to the bores.
Costs / Euro:
Display 59,-
Taobao agent: 15,-
Shipping: 24,-
Regarding the repair procedure by Markus in his Coneheads.de blog:
http://new.mash.webclient6.de/index.php/bauen/sonstiges/47-agilentu1252he didn´t mention where he got the display from, which i suppose is this:
https://lcdstore.de/OLED-Modul-128x64-Punkte-monochromIt is obsolete, but there is a replacement, for which you need an additional pcb:
https://lcdstore.de/epages/17406888.sf/de_DE/?ObjectPath=/Shops/17406888/Products/CFAL12864J-Yhttps://lcdstore.de/epages/17406888.sf/de_DE/?ObjectPath=/Shops/17406888/Products/Command-Switch-2So whichever way you choose to replace your display, maybe you find some help here, as i did on this great forum.
Thanks to all.
Edit: posting images here is a bit tricky ...
