Author Topic: Siglent SDM3055 - stuck on boot screen  (Read 49617 times)
Offline dvp
  • Country: ru
Re: Siglent SDM3055 - stuck on boot screen
« Reply #175 on: July 05, 2024, 12:21:39 pm »
My device SDM 3055 is 7 years old, it worked fine. I haven't used it for about a year, but now, after turning it on, it freezes on the download screen. I need help restoring the device, help me.
Welcome to the forum.
Can I ask if this old meter has ever had its firmware updated ?
If No, it must be returned to Siglent for specialized recovery and calibration.
Yes, it was updated, but a very long time ago, about 3 years ago, and I do not remember the firmware number.
Offline rf-loop
« Reply #176 on: July 05, 2024, 03:07:46 pm »
If you have updated it as you said, it is obvious that there is U-disk recovery in the firmware.
2017/4/14 FW 1.01.01.19 1. Added U disk recovery function.
Ref attached version history.
Offline tautech
« Reply #177 on: July 05, 2024, 09:53:34 pm »
Good, clues to providing a successful recovery are below.
Please send personal message with your email address.
Offline dvp
  • Country: ru
« Reply #178 on: July 08, 2024, 07:39:07 am »
tauech. Thank you, I sent PM
Offline tautech
« Reply #179 on: July 08, 2024, 08:22:37 am »
Email sent yesterday.
Offline dvp
  • Country: ru
« Reply #180 on: July 08, 2024, 07:01:19 pm »
tautech, Thanks! My "dinosaur" came to life and is back in operation, it was version 1.01.01.25, now it has been updated to the latest version. It's working well so far.
Offline Monte Quercus
« Reply #181 on: July 13, 2024, 11:24:35 pm »
Hello and thank you for the welcome!
I just wanted to share that I was able to successfully recover my SDM3055 with the provided files and a SamData 8GB USB Flash Drive as offered on Amazon here: https://www.amazon.com/dp/B092879BVB?ref=ppx_yo2ov_dt_b_product_details&th=1.
Offline concerto51
« Reply #182 on: July 17, 2024, 09:07:51 pm »
Hello, I encounter the same problem. my SDM3055 was not powered up for a few months and today it's stuck on boot screen. I think I already upgraded it to version 1.01.01.19 a few years ago but I'm not sure.
Please can you send me the recovery files.
best regards
Lorenzo
Offline jmg-arati
« Reply #183 on: July 19, 2024, 01:55:16 pm »
Hello everybody !
Unfortunately, my case is not very original. I own a Siglent SDM 3055 who is stucked at boot screen.
It's the second time it happened to me.
The first time I contacted SIglent, and they sent ma a link to a "SDM3055 Recovery by U disk.zip" file that i downloaded, put its files on a 2 GB FAT32 USB disk, and was able to recover my unit from that.
I then installed a more recent firmware (may be the 1.01.01.20...).
But it just happened again yesterday : freeze at boot screen, after the unit stayed without power cable connected for some days.
The bad new is that the recovery USB disk trick don't seems to work anymore ! The 3055 just read quickly the USB disk at startup, but no recovery happens, and it stays frozen...
So what to do ? Maybe you have some useful informations to help me with this challenge ?
By advance, thank you ! Regards.
Offline tautech
« Reply #184 on: July 19, 2024, 01:59:09 pm »
Hello everybody !
Check your messages.
Offline jmg-arati
« Reply #185 on: July 19, 2024, 03:25:07 pm »
Thank you so much tautech !
You were very fast to send me new USB recovery files (different from those sent to me by Siglent, some years ago), who worked like a charm !
I just installed the latest 3055 firmware (the 1.02.01.27R2, followed by the 1.02.01.28, hoping this behaviour will not come back in some months/years.
I will keep an eye on this forum, also. Bye.
Offline vikorona
  • Country: id
« Reply #186 on: August 05, 2024, 09:43:30 am »
Hello,
Today, my SDM3055 also stuck at the start logo screen...
A few months ago it was updated to 1.01.01.25.
Can someone help me with the recovery file?
Offline tautech
« Reply #187 on: August 05, 2024, 09:54:40 am »
Hello,
Offline Hoggy
« Reply #188 on: August 09, 2024, 12:21:36 am »
It seems my SDM3065X has joined the list of frozen boot screen devices.  I haven't used much of my equipment lately, and keep it off using a power-strip to save from things like lightning strikes.
It should already have the latest firmware file that I put on it a few months back: SDM3065X_V3.01.01.12R1.ADS
Offline klausES
  • Restore Sony ES/Esprit era
« Reply #189 on: August 09, 2024, 03:30:03 pm »
If there are no coincidences, it almost sounds as if there is a connection with a longer standstill time.
But what should it be if this would be true ?
A memory that would need a battery or a goldcab is not in my knowledge in the SDM.... ?!?
Is there a flash memory type that could create a long -term problem ?
Would anyone have a possible explanation ?
regards klaus. "Art is when you can't do it ... because if you can, it's not art"
Online nctnico
« Reply #190 on: August 09, 2024, 06:52:07 pm »
Yes, and it is called NAND-flash and it used for storage almost exclusively nowadays. What is needed to use this kind of memory for long term storage is error-correction (redundant) data and regular refresh of the data. If this isn't implemented correctly, a device is likely to fail due to the flash contents getting corrupted over time.
The following users thanked this post: egonotto, tautech
Offline klausES
« Reply #191 on: August 11, 2024, 03:01:22 pm »
I wouldn't have thought that from Flash memory.
Thought that some cells could eventually be damaged by a large number of writing processes, but not from a standstill.  :-\
That horrified me now.
Offline dbouvier
  • Country: uy
« Reply #192 on: August 17, 2024, 02:11:31 am »
Hi, I'm a long time reader of the forum, first post.
Recently I've bought an used SDM3055 on Ebay and the seller forgot (😏) to mention that it was stuck at boot screen. I plugged an old 2Gb pendrive (the only one my Rigol scope is able to read) and the "activity" light on the pendrive blinks, so I think the DMM is trying to read it.
Can somebody help me providing the required files to recover the DMM?. I will very much appreciate it. Of course I will upgrade the FW to the last version after recovering.
Have a good day!!
Offline tautech
« Reply #193 on: August 17, 2024, 02:14:14 am »
Have a good day!!
