Hey guys. I ran into some broken Xantrex XPH power supplies with missing output buttons. I've attached the CAD in stl for 3d printing the button.
These buttons should work on several sorensen / xantrex / tti model power supplies.
Here's what it looks like on the front panel now (the black button in the bottom right corner)
The measurements were taken with a caliper on an OEM button from another psu.
![](https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/?action=dlattach;attach=760347;image)
![](https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/?action=dlattach;attach=760353;image)
![](https://www.eevblog.com/forum/testgear/replacement-knobs-feet-and-fittings-for-test-equipment/?action=dlattach;attach=760362;image)
The plastic button is a press-in install. You don't need to remove the front panel of the PSU to install it. The PSU uses a latched output button like old 90s computers. The button stalk is even similar in size.
The part is tiny (less than 0.5in x 0.25in x 0.25in size) and should only take minutes to 3d print.
There are (2) files attached. One features a perfectly cylindrical button and the other has a 1 degree draft.
The OEM output button has a 2 degree draft, but it is purely cosmetic and may cause problems in 3d printing when printing from the side of the smaller diameter.
Ideally, you want to print from the side of the button without the hole so you don't need to clear any support material.
Let me know what you think!
