Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Small pin probe < 20 mils
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Small pin probe < 20 mils (Read 787 times)
Jester
Frequent Contributor
Country:
on:
March 02, 2019, 01:47:40 pm »
At times I need to connect a probe to small through-hole test points that are in the 0.020-0.025" range. Typically low frequency.
The commonly available jumpers I use have round pins of 0.025" diameter
These Mill-Max sockets make for a convenient way to adapt the 0.025" test probe to a 0.020" diameter, you can simply snap them on or off as required ->
https://www.mill-max.com/assets/pdfs/065.pdf
I'm looking for a slightly smaller version, under 0.020" pin diameter, any suggestions?
Last Edit: March 02, 2019, 02:14:41 pm by Jester
Logged
HalFET
Country:
Re: Small pin probe < 20 mils
Reply #1 on:
March 02, 2019, 02:20:41 pm »
I use old probe station needles hooked up to a regular probe with a screw terminal. Works great, and you can even slide the tip underneath QFNs.
Logged
DaJMasta
Super Contributor
Country:
Reply #2 on:
March 02, 2019, 10:20:31 pm »
In the past, I've just gone with Kynar wire soldered in place. Takes only a few moments to put on if you have the solder station near you, very easy/clean to undo, and a more durable connection than most clips or points.
Logged
http://www.medpants.com/
- W3BSN
tautech
Super Contributor
Country:
Taupaki Technologies Ltd. Siglent Distributor NZ.
Reply #3 on:
March 02, 2019, 10:34:05 pm »
For your own boards or general usage ?
The Tek grabber you're using already is probably the best without needing to spend $$$ to get something better.
For your own designs use some SMD test points and put a footprint onto a trace and define both pads to the same net to avoid any DRC errors. That also allows you to pull them out once testing is done and reuse them.
In 0805 size ordinary scope probe hooks can easily be used for connections.
Logged
Avid
Rabid
Hobbyist.
Siglent Youtube channel:
https://www.youtube.com/@SiglentVideo/videos
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
