I'm not sure the right place to put this, so here goes...
I'm working on crufty software to use a higher quality sound card as an audio test interface, for my use only. I know other software exists that I could use, but a man has to have a hobby. I also what to have repeatability in the testing - so I know things will be exactly the same when testing on different days. I'm not really after a GUI, just an objective set of tests I can run to measure performance of the unit under test under different conditions.
I've got programming ALSA all sorted, and for this current setup I play a 1000kHz tone at 48kHz, 16-bit, while also recording line in. (as I am currently using my development laptops's onboard 16-bit CODEC for now). I've got a loopback cable from out to input.
The noise is about +/- 14 counts RMS, the signal +/-30.000 counts. I've got my basic analysis going - collecting 4800 samples (0.1s) and running an DFT on them (no FFT yet, as I'm just playing around and performance isn't important). With 0.1s of data each DFT bin ends up to be 10Hz.
A plot of the results is attached.
So... a long build up to the question.
As you increase frequency resolution (longer data set, longer DFT, more bins in the result), I *assume* the noise per bin reduces too - after all, the total power has to remain the same. On a graph the noise floor will get lower.
How do I standardize the measurement so I get roughly scale-invariant metric of noise, regardless of DFT length?
Do I divide the bin's power by the width in Hz to get "power per Hz"?
Do I just remove the test tone bin, and calculate the power of the rest (I guess that leave THD+noise)?
Am I overthinking this?
Or maybe more importantly, are my assumptions wrong?
