Author Topic: Repair of a Fluke 87 lll  (Read 1001 times)
Offline QmavamTopic starter
« on: June 05, 2023, 12:12:57 pm »
  I have a Fluke 87 lll that had over voltage AC applied.
I checked all the MOVs and they seem fine.
 Any experience fixing an 87 lll that had too much voltage applied?
 What should I look at?
                   Thanks, Mikek
Offline BeBuLamar
Re: Repair of a Fluke 87 lll
« Reply #1 on: June 05, 2023, 02:01:11 pm »
What does it do now? It doesn't power up? Overvotage AC applied how high was the voltage and in which mode the meter was in?
Online Fungus
« Reply #2 on: June 05, 2023, 07:33:03 pm »
How much is "too much"?
If it powers on and responds then try removing the two clamping transistors to see what happens.
Offline BeBuLamar
« Reply #3 on: June 05, 2023, 08:10:20 pm »
The company I work for had a number of 87III and they tend to have problem with the display. None had any other problems.
Offline Ugur
  • Country: tr
« Reply #4 on: June 06, 2023, 05:58:01 am »
Turn it into Ohms and do you see OL on the screen? If not, check the varistors.
Offline EEVblog
« Reply #5 on: June 06, 2023, 07:25:28 am »
Does the display still work but it just reads zero?
Check the series input resistor. I think it's a fusible type.
The following users thanked this post: paulbt
« Reply #6 on: June 19, 2023, 03:21:52 pm »
It turned out to be one MOV that was defective.
            Thanks all, Qmavam
