I've had this Fluke 6060B sig gen for 15 years and great performance on all frequencies. July 2023, I discovered the frequencies below 245 MHz were missing. Above 245 MHz every thing was OK. Signal HETL toggles between the two frequency bands.
![Repair / Fluke 6060B RF signal generator. <245 MHz missing , >245 MHz OK](https://www.eevblog.com/forum/index.php?action=dlattach;topic=389422.0;attach=1854583;image)
After much troubleshooting it was discovered the HETL signal path to pin diode CR 210 was 1.6 ohms above ground.
![Repair / Fluke 6060B RF signal generator. <245 MHz missing , >245 MHz OK](https://www.eevblog.com/forum/index.php?action=dlattach;topic=389422.0;attach=1854589;image)
Trouble shooting required cutting some traces with an exacto knife.
The problem located toward the 2.2 UF electrolytic capacitor C276.
![Repair / Fluke 6060B RF signal generator. <245 MHz missing , >245 MHz OK](https://www.eevblog.com/forum/index.php?action=dlattach;topic=389422.0;attach=1854595;image)
The fault turned out to be a whisker had grown from the positive terminal
of the solder joint of C276 to ground. The short remained after the capacitor
was removed. I had to cut the area around the square solder land with an exacto
knife to clear the short. C276 was good and soldered back in place. It took 30+ years
for the whisker to grow across the gap between the Positive terminal of C276 and ground.
![Repair / Fluke 6060B RF signal generator. <245 MHz missing , >245 MHz OK](https://www.eevblog.com/forum/index.php?action=dlattach;topic=389422.0;attach=1854601;image)
