Long time ago I converted a ZeroPlus logic analyzer from 16032 to 162000.
I have not fully tested the changes, I have succesfully tested a 5 MHz square signal ( which is the max frequency on my signal generator )
The specs are:
For the 16032:
- Internal Clock (Timing Mode)?100Hz?100MHz
- Memory?512Kbits
- Memory Depth(Per Channel)?32Kbits
For the 16200:
- Internal Sampling Frequency: 100Hz?200MHz
- RAM Size: 64Mbits
- Memory Depth per Channel: 2Mbits
How can I test all these parameters on the converted unit ?
The software recognizes all of them.
David.
