I have never used the one you link to but would say like any equipment, depends what you need. For me, there is no one simple probe solution.
For DC to 100MHz in the 1mA to 1A range, I have a very old Tektronix P6042 that I modified. Below 1MHz, these probes can handle 20Ap-p.
If you are just a hobbyist, I see no reason you could not roll your own. It sounds like you may not even have a need for one yet and are just interested in playing with one. Maybe just wait a while. This video shows where I followed an article about using a split-core to make one. There is a link to the article in the description.
I like the UNI-T UT210E as a general purpose clamp. The fact it can resolve down to 1mA makes it a no brainer for hunting automotive electrical problems. It can also measure up to 100A. I added an analog output to one just using a small buffer amp.
The bandwidth on these is only a few KHz. But because they are so cheap, there was no reason not to take a crack at modifying one to up the response. This may be the highest BW UT210E on the planet. It took a fair amount of effort to come up with a workable design. For me anyway, designing and constructing things is what I enjoy doing with electronics.
