Author Topic: Can the digital oscilloscope display G321EV be replaced with a different model?  (Read 391 times)
Online daisizhouTopic starter
  • Country: cn
Hallo every one
This is one of my oscilloscopes. I have been using it for many years.
Recently I noticed a circular shadow in the center of the screen,It looks like the glue that bonds the LCD has aged.
I was wondering if there is a replacement for this model of LCD screen?Because the same model is very expensive
The LCD module model is G321EV. Is there any other model of LCD module that can be a perfect replacement?
Because if I buy the G321EV, after a period of use, the aging will appear again. I hope to completely solve the screen aging.
« Last Edit: August 13, 2024, 06:23:45 am by daisizhou »
daisizhou#sina.com #=@
Online Fungus
You need to separate the screen from the PCB and see if there's any numbers printed on it.
Offline squadchannel
  • Country: jp
  • deepl translate user
Electrically, it should work with the same screen size, resolution, and controller.
But mechanically, I don't think it can be installed. It is better to purchase the same LCD panel or replace the polarizer.
  • Country: cn
As I thought, I initially mistakenly thought it was caused by the aging of the polarizer, but please see the following picture
The entire screen is made of a horizontal liquid crystal and a vertical liquid crystal bonded together.The horizontal direction is welded by zebra strips, and the vertical direction is conductive rubber.
I guess it's because the glue that bonds them together has aged.
If I buy the same model, I estimate that the same problem will occur again after a period of time, so I hope to completely solve this problem.
  • Country: cn
It looks like the LCD module model is G321EV。
There is no point in buying the same model because the fault will reoccur over time, so I am looking for a perfect replacement model.
