Hi Voxman,
First of all, you shouldn´t give away your scope after buying a new one - Analog scopes still got advantages against digital ones.
Then, 250 bucks....hm-hm, in that range you should have a look at used rigol ds1054Z models.
It´s not only the 4 channels ( which you won´t need) it´s got more than a DS1052E model, so look at it, very recommendable.
Try to get some as cheap as possible, because for your measurings up to 450vdc you will need a differential probe today.
Take a look to the micsig differential probes, god value for money.
Martin
